  New Posts New Posts RSS Feed: Checking brake lights
Topic ClosedChecking brake lights
JStrube View Drop Down
Direct Link To This Post Topic: Checking brake lights
    Posted: 25 Nov 2014 at 9:55pm
I've always used rt turn signal, then left.  Same as flashers.
2012 181G
Podster View Drop Down
Direct Link To This Post Posted: 25 Nov 2014 at 9:08pm
Using the remote is a great idea, and I think I'm OK with 99%.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 25 Nov 2014 at 8:33pm
You can be 99% certain your brake lights are ok if you do the hazard flasher test mentioned.  Personally I use my truck's remote, pressing the unlock button which flashes all of the lights.
Direct Link To This Post Posted: 25 Nov 2014 at 4:04pm
Some may suggest that you can turn on your four way flashers and if they work your brakes lights will work. The problem with this is that some wiring configurations may not support the test and there are other components in the brake light system that can fail and will leave the 4 ways (Hazards) working while the brake lights are failing. E.g., The brake light switch...When solo, the only way to be absolutely certain the break lights are working properly is to step on the brake pedal, so I think a wooden dowel cut to the perfect length could be used to hold the brake pedal in place. Thanks for bringing this subject up. I just added "brake pedal dowel" to my to do checklist. Thumbs Up
Cliff & Raelynn
Ranger 4.0/178
Happy Tripping View Drop Down
Direct Link To This Post Posted: 25 Nov 2014 at 3:01pm
I am new to trailering. My wife is sometimes unavailable. When solo I have been told by one person to back my trailer against a light colored wall to check to see if the brakes are working. I have successfully wedged a block of wood against the brake pedal and gotten out and looked at the brake light, early on I tried to rig a mirror that I could see from the driver's seat, less successfully.
I need a fool proof (for me) method for checking brake lights. Any suggestions??
