Page 12> |
NormanHill ![]() Groupie ![]() Joined: 30 Mar 2014 Online Status: Offline Posts: 49 |
![]() Posted: 15 Oct 2014 at 11:37pm |
I've shared my frustration with FR quality here before, with others defending them and saying the dealer should fix it. I suggest calling FR on the AC box issue and see what they say. It would be an expensive thing to fix. FR has the quality problem and the dealers just don't push back on them for owners.
It's ridiculous to call poor assembly a warranty issue. Oh, and don't blame the engineers, I am one :) |
I count this as four serial screw-ups: The first guy cut the hole in the wrong place, the scond guy covered it up with an outlet box plate, the third guy installed the AC shroud without raising the goof flag, and the fourth final QA guy closed his eyes. Does that last guy even exist?? Inexcusable. |
Something to consider, tanks for the info.
In my little sis's class C, they made a simple pvc ladder for the bunk above the cab. Easy and light.
Not to go off topic, marwayne's pic reminded me - I need to figure out a step or ladder for my Salem. Since it has a triple-bunk the top bunk is really high, too high even with a 2-step stool on the floor. Same configuration as show above so I've considered putting a ladder or steps on the bathroom wall.
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1003 |
I fixed it in my pod, but it still bothers me when I see it in another pod.
Now that's an interesting backband and jack-miter! Do your best and caulk the rest?
![]() fred
Here is my pet peeve, and I have seen a lot worse in other pods.
Luv2Q ![]() Senior Member ![]() ![]() Joined: 30 Aug 2014 Location: Central TX Online Status: Offline Posts: 309 |
I'm with JStrube: It's the kind of sloppiness that can drive most of us nuts!
You're probably now in a quandary: Do you take the time, trouble & hassle to take it to an FR dealer? Or do you trim the cover plate to get rid of the gap? Neither is particularly satisfactory since it could/should have been right in the first place. If it were me: I'd take it to the dealer & get it done right. After all, it's brand spanking new! If I were to trim the plate then, every time I looked up to change a vent, I'd get ticked off. Then I'd have to go have a Jack Daniels to get calmed down. Then I'd need an Alka Seltzer to get my stomach settled down. And then ... But .. YMMV. Good luck whichever way you go. And "get a life"? Hell no .. Like I said, the dang thing is brand new! (See? I'm getting worked up, and it's your trailer! I think I need anger management counseling.)
John & Teri
Tundra 5.7L V8 / RP 180 E2 WDH / Integrated controller (POS) replaced by Tekonsha P3 |
JStrube ![]() Groupie ![]() Joined: 11 Aug 2014 Location: Atwater, CA Online Status: Offline Posts: 90 |
That is the kind of thing that drives me crazy. Could you imagine Honda doing that? Would you accept it from Honda?
2012 181G
Page 12> |
