Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
![]() Posted: 13 Oct 2014 at 7:39pm |
Oh wow, I didn't think of that...pests could very well be a problem here in Southern Texas as well.
Cliff & Raelynn
J&Jcf ![]() Groupie ![]() Joined: 17 Aug 2014 Location: central Florida Online Status: Offline Posts: 90 |
I live in Florida and do not put them down. This helps prevent ants and other pest from entering
the pod . I use bug spray on wheels and tongue jack to prevent pests from using them to enter and establish a nest. I had carpenter ants try to establish a home in previous TT. They were hard to get rid of. |
J. - 2011 rpod 171
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
Yes. I park it behind my house for the Winter, block the wheels, and put the stabilizers down on bricks to protect my patio.
ron_whitt ![]() Senior Member ![]() ![]() Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
North of 49 the frost goes down min. of 3.5 ft. If it thaws and refreezes and the jacks were down, the ground would push some of the jacks up thereby putting pressure on the ones that would not be pushed up. (If this makes any sense.) So I've been told not to put the jacks down, it might put stress on the body frame with the jacks raising at different times and heights. And lets not talk about the real spring thaw......
Ron & Shirley
2020 Tacoma 2012 177 rpod |
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1060 |
I do. hogone
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
I would say no also. My reason is because I store mine near my house on relatively soft ground. Tires sink just a bit and it's hanging up on the stabilizers. Would do the same if tire went flat on you.
For our 171, no. Since the bed is in the back there's almost no reason to go into the rear 1/3, so it won't tip up. No need for front stabilizers for any model in storage (and the early pods didn't even come with them).
It would seem like the right thing to do, do you'all deploy your POD stabilizers when it's sitting in storage?
Cliff & Raelynn
