  New Posts New Posts RSS Feed: Battery
Topic ClosedBattery
rcamper View Drop Down
Direct Link To This Post Topic: Battery
    Posted: 26 Sep 2014 at 7:09pm
i was told red is always positive if that helps. . have a charger in the garage to keep the battery juiced when not camping
gone camping
Direct Link To This Post Posted: 23 Sep 2014 at 9:29pm
Alternatively, make sure neither end is touching the frame and plug the pod in, then take a voltmeter to them if you have one.
rokndrumr View Drop Down
Direct Link To This Post Posted: 23 Sep 2014 at 8:18pm
Thank you!
Sean & Jerri
kymooses View Drop Down
Direct Link To This Post Posted: 23 Sep 2014 at 7:19pm
i would give you the color choice, but who knows if one random day someone installed something backwards on your Pod.
so, follow the cables, one of them attaches the frame of your Rpod just behind where the battery box sits right underneath the front of the Pod.  whatever color that one is will go to your negative terminal.
having said that....that one should be the white and the red should be your positive going into the Pod.
Direct Link To This Post Posted: 23 Sep 2014 at 7:08pm
I took my old battery off, and purchased a new one. I have a white, and a red lead coming from the camper, but I can't remember which one is positive and negative. I don't want to mess anything up.
Little help here?Cry
Sean & Jerri
