  New Posts New Posts RSS Feed: water pump cycling.
Topic Closedwater pump cycling.
ahefner View Drop Down
Direct Link To This Post Topic: water pump cycling.
    Posted: 18 Aug 2014 at 5:17pm
I checked the last time I went out and had no problems with the pump cycling. It was either some trash in the valve or an air pocket somewhere.
2014 rPod 178
2014 Toyota Tundra 5.7
Direct Link To This Post Posted: 02 Aug 2014 at 8:38pm
I normally have full hookups. My last trip I had to use the pump. Actually I think it was the first time I have really ever used it for any period of time.
2014 rPod 178
Direct Link To This Post Posted: 02 Aug 2014 at 8:05pm
If the overpressure valve on the water heater is failing, you'll see water leaking from it.
Budward View Drop Down
Direct Link To This Post Posted: 02 Aug 2014 at 7:26pm
You wouldn't see water if it is a leaking check valve, it bleeds pressure off back into the supply side.
Do you use the water much?  If not I'd cycle a bunch water through it and see if it clears.  It might.
Or you might have to disassemble the pump and clean.
I don't think mine runs at all overnight.
2014 179
Direct Link To This Post Posted: 02 Aug 2014 at 6:44pm
How does a person check then check valve? I haven't seen any signs of water anywhere.
2014 rPod 178
Direct Link To This Post Posted: 02 Aug 2014 at 11:30am
I've heard mine cycle briefly once or twice in the middle of the night, I'm sure for the reasons Charlie mentioned (and possibly temperature changes).  If you are hearing it often, an area to check is the water heater overpressure valve, outside, at the top of the water heater.
CharlieM View Drop Down
Direct Link To This Post Posted: 02 Aug 2014 at 8:17am
You might hear the pump cycle once or twice after water uses ceases. This is due to the hoses expanding and/or air being absorbed into the water under pressure. This is normal, most noted at night when things are quiet, but should not continue. A continuing cycling indicates a possible check valve leak as Budward mentions. However you should also check for real water leaks, including outside and under the Pod. Loose water fittings have been found.
Direct Link To This Post Posted: 02 Aug 2014 at 4:48am
Yep- leak.   It could be leaking back through the check valve in the pump if there is a small amount of debris in it.
2014 179
Cap-n-Cray View Drop Down
Direct Link To This Post Posted: 02 Aug 2014 at 1:46am
Sounds like a leak somewhere or losing pressure.
I accidentally left my water pump on all night and it didn't make a sound.
Cary
2014 RP-177
Direct Link To This Post Posted: 02 Aug 2014 at 12:39am
Is it normal for the water pump to cycle every so often when the faucets are off? I going to guess this happens once an hour. Maybe less often that that..
2014 rPod 178
