Page 123> |
Inge ![]() Newbie ![]() ![]() Joined: 30 Jul 2014 Online Status: Offline Posts: 34 |
![]() Posted: 01 Aug 2014 at 12:38am |
Thanks everybody for all the information. My current thinking is to get the following: Get a pump as Wildfire suggested with stainless steel mesh filter spares for pump strainer (Have to find out how to replace them) Microbox tank care (clean, fresh and micropur) Aquasana filter for drinking water (removes Giardia) Plus a torque wrench so I won't loose the tires while I'm transporting all that good water (thanks for this great suggestion hogone!!!)
"Bommel" - r-pod 182 G " Franzi" - Toyota Tundra 2007 http://blog.picturingtheamericas.com |
Backpacker here. I've always relied on chemical treatment - but not bleach or iodine. I love Aqua Mira for multiple reasons.
I would recommend chemical treatment, assuming the water source isn't cloudy or has a lot of suspended particles. Those issues could be handled by a simple pre-filter that doesn't do any purification. Iodine has taste issues. Aqua Mira would be prohibitive from a cost standpoint. In this case I recommend plain bleach added while the tank is being filled so it mixes. 6 teaspoons for 30 gallons. Let it sit at least an hour, more if it is cold water, and you'll be good. You may want to go even longer to ensure it handles the nasties like Giardia. There will be a slight odor and taste but it will be a much easier and faster procedure than mechanical filtering.
Yes, no electricity needed. Berkey's are pure gravity filters. I would take a "Big Berkey" and a spare set of filters. The black filters are what you need for your use. I won't say what I have seen them filter in the middle east, I will just say, they will work for everything you need. They will make potable water from whatever source you have. No fuel, no electricity needed. The filters are also cleanable. How long are you planning to stay down there? I would take some bleach tablets to sanitize the tank evry now and then, just in case. It's not really a giant issue to get a few nasties in the system, but it's bad if they have time to multiply and gang up on you. |
Camper Bob ![]() podders Helping podders - pHp ![]() Joined: 26 Sep 2011 Location: Portland Oregon Online Status: Offline Posts: 913 |
Another suggestion. When we went camping many years ago with our sons I did some research on water filters. Many types but I wanted one that would keep us safe from bacteria, heavy metals, giardia, etc. I settled on the Everpure system which is installed inside the trailer under the kitchen sink. Since you usually only drink from the cold side, this is where the filter is installed. A little slow to fill a glass but we have never had "funny tummy" in all the years of travel. Camping World carries it as well as the replaceable cartridges. Look up the specs on each and every filter before you make a purchase. We installed one on our Pod and never looked back. Better to be an informed buyer. Safe Travels.
Camper Bob and Camper Sue
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1062 |
inge: not sure when the excursion starts but long thread going on about loose/losing wheels............have a torque wrench (100 lbs) to tightened wheels(lugs). hogone
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
Girls?! Oh My!
OK, got that out of the way. We always carry drinking water separate from tanked water. If I couldn't buy bottled water, I would probably look at a distiller. I hear good things about the Nutriteam Distiller. @ 580 watts, you would need to be plugged in or a pretty good sized power system (solar/batteries/inverter) to make a gallon of very safe water in 5-6 hours. I could see running it on the road via an inverter - sorta like the Tow Vehicle crock pot chicken! fred
wildfire305 ![]() Groupie ![]() ![]() Joined: 22 Jul 2014 Location: Erlanger, KY Online Status: Offline Posts: 85 |
sorry I may have seemed a little rude earlier I just had to warm up to the idea of what you're doing.I almost forgot that there is a small strainer on the pump already installed in the camper you'll want some spares for that too.
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey 2015 RP179 "73b" OLD 2005 Viking Saga 2480ST popup |
Just saw your message, furpod. Didn't expect there to be a second page already :-)
Would you pour in the water and then just wait till it's filtered, no electricity needed? hogone: don't worry, no problem at all!
Well you just need a basic whole house sediment filter adapted with garden hose fittings and plenty of spare cartridges. Should budget $50 from any big box store. Stainless steel mesh filter would be cleanable instead of paper filters. I would go with a shurflo 3gpm pump 12 volt for transfer (it's the same pump you already have in the camper). Those are only $70. You will want to read up on maximum suction hose length and head pressure height and stay under those limits when filling. A pump is rated by gpm at certain height and suction length. In other words the pump might not work at all if you are 100 feet from the source uphill 20 feet. You could consider a 120 volt pump and an inverter ran from the tow vehicle.
That won't help with bacteria though so I would add bleach to your holding tank so you can safely shower and wash cookware. Then I would have something completely separate for drinking and cooking with. The backpacking filter bottles should work. Argentina - invest in lots of locks and chains for your equipment. |
a very excellent option furpod. sorry inge, shouldn't have referred to you as 'he' in a prior post. sounds like quite the excursion. hogone
Jon & Pam
Page 123> |
