  New Posts New Posts RSS Feed: Using propane to run refrigerator
Topic ClosedUsing propane to run refrigerator - Event Date: 28 Jul 2014
Outbound View Drop Down
Direct Link To This Post Calendar Event: Using propane to run refrigerator
    Posted: 29 Jul 2014 at 6:53pm
Two years ago, I had a rather large spider set up shop in the flue of my propane fridge.  When I lit the fridge, the spider (and his nest) cooked fairly well, mostly blocking the flue and preventing my fridge was staying lit.  Fortunately, a can of compressed air (for cleaning computers) was able to clear out the mess and my fridge has worked properly since.
You may or may not have a similar issue - but its worth checking.
Direct Link To This Post Posted: 28 Jul 2014 at 11:21pm
How old is your fridge?  At 4 years old the LP mode has mostly stopped working.  New orifice, and the dealer says they think it is the gas valve.
Direct Link To This Post Posted: 28 Jul 2014 at 3:47pm
What is the state of your 12v system?
The fridge MUST have 12v to run in ANY mode.
If it was put into propane mode and errored out for some reason, it needs to be reset before it will attempt to light. Turn it all the way off for 5 minutes turn back on, select gas mode.
Eldon View Drop Down
Direct Link To This Post Posted: 28 Jul 2014 at 3:31pm
The propane function on my refrigerator quit working. It has been perfect in the past, but just quit, does not attempt to light. Have bled the line, the cooktop and heater work fine. Any suggestions?
Eldon
