  New Posts New Posts RSS Feed: refrigerator or water heater question
Topic Closedrefrigerator or water heater question
Direct Link To This Post Topic: refrigerator or water heater question
    Posted: 11 Jul 2014 at 1:07am
True. With our popup I always left the WH off all day after taking morning showers. We would still have very warm water to do dishes at night.
CharlieM View Drop Down
Direct Link To This Post Posted: 10 Jul 2014 at 10:19am
As for the water heater, I would leave that off while on the road.  It only takes 10 minutes to heat the water once you are in-camp.
And if the water is initially hot it will stay warm for hours and hours for use on the road. No need to run WH while driving.
Direct Link To This Post Posted: 10 Jul 2014 at 12:47am
No issues running your fridge on LPG while on the road, the larger RVs only have LPG as an option on the road (no DC mode).  LPG mode uses very little propane and usually works the best so it is my preferred option unless we have an AC connection at a campground.
Remember you can't use the DC mode when boondocking (no connections) or you will kill you battery within a few hours.  You must use LPG mode.
Elkhart View Drop Down
Direct Link To This Post Posted: 09 Jul 2014 at 9:42pm
Is it ok to run your refrigerator or water heater on propane while you are on the road traveling?
Keith & Kelly
2012 171 Pod
2013 Ford F150 TV
