Page 12> |
Author | ||
NXRocks ![]() Newbie ![]() ![]() Joined: 27 Apr 2014 Location: Evergreen, CO Online Status: Offline Posts: 24 |
![]() Posted: 03 Jul 2014 at 9:47am |
2009 R-Pod 172 Lifted 4"
2008 Nissan Xterra built up - too much to list Computer Engineer with metal work as a hobby - or more - former NXRocks manufacturing First time RV Camper - this better be good |
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
The engine hoist works well- I have an Onan 4kw that is designed as a built in- originally I had it on a receiver platform that I plugged into the front receiver hitch on my F350 when it hauled a large Jayco truck camper.
An engine hoist is exactly how I did it! The Onan generator alone is 200lb and probably had another 50 of support steel. That generator is now installed in my 1999 Tahoe toy hauler...book value on that rig is now less than the generator is worth, to me anyway. Someday I may trash the RV portion, selling the appliances, which all still work, and turning it into a 25ft flat bed. It has a much stouter frame than travel trailers usually have with a 10k lb GVWR being a toy hauler. I can't buy a 25' flat bed for what the trailer book is now! |
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
Budward, I would be interested in a write-up of your gas tank mod.
I'm hoping the weight is a good extra deterrent to keep anyone from taking my Honda! Eventually I need to buy or build an engine hoist so I can mount it w/o help from my 12 year old daughter. I'm fortunate that she is very strong.
granlobo, If you go with a generator- I would recommend the Yamaha EF2400iSHC. This is the newer "high current surge" model designed to start most RV air conditioners.
Anything smaller and you risk being on the edge and not being able to start the AC, such as high ambient temp or high altitude. The big drawback I see to the EF2400iSHC is a relatively small tank that may not make it through an overnight if the AC is running a lot. I made a method to attach a 5 gallon steel military style can to mine. There is a commercial version marketed also. As stated campgrounds vary greatly with regards to generator use- my favorite allows only 2 hours per day between 9-6. My next allows 4 hours between 9-8. My third allows between 9-8 all you want! I've personally never encountered a true "campground" that allowed generators 24 hrs a day but I'm sure some might somewhere. While traveling I have overnighted in WalMart and truck stop parking lots where I ran mine all night...not even noticed with idling big rigs. Whatever you buy do not get a cheap (LOUD) one as you might be evicted or even worse by other campers ![]() PS the Honda EU3000is is a great generator- Like techntrek I own one also, it is just too heavy for one (normal) person to lift and move. |
2014 179
Keep in mind with gensets in the 2000-2400 watt range, you will only be able to run one of the big appliances at one time - A/C, microwave, electric element in the water heater. So if you are running the A/C and want to nuke dinner, you must turn the A/C off until you are done. We did it last year when we had the Yamaha EF2400is, but after doing that for 10 minutes it will start to get warm inside the pod. This was a secondary reason I upgraded to a Honda EU3000is this spring since it will run both at the same time.
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
Yes I have - with a Supco SPP6 (link); its a direct replacement and it took longer to pull the ladder out of the garage than it did to install it. Note: the SPP6 is the appropriate one for my A/C - different models over the years may well have different requirements, so you'll have to do some research. I have a six year-old Hyundai 2200 watt peak / 2000 watt running inverter generator that it works quite well with. I like my old Korean knock-off genny and was glad that a cheap start-cap was able to keep it in service.
Thank you. We were all newbies at one time.
granlobo ![]() Newbie ![]() Joined: 21 Jun 2014 Online Status: Offline Posts: 4 |
Thanks, Doug. I've only "known" you for a short time...but you're the real deal. Thanks for the information and for your kind demeanor in dealing with "new" people. You remind me of some of the kind, helpful "Harley" people I grew up with, and not the "others".
[QUOTE=furpod]Also, here is a good link, some info is a little behind the times, but the main meat of the 12v world has been the same for a long time..
http://www.marxrv.com/12volt/12volt.htm [/QUOTE Wow! That's the stuff right there...thank you so much! Helps to really understand what you're contemplating! What a great resource!
Cap-n-Cray ![]() Senior Member ![]() ![]() Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
Have you done this? That is very interesting. Maybe another thread on this... Thanks |
Cary
2014 RP-177 |
Page 12> |
