  New Posts New Posts RSS Feed: Furnace and AC
Topic ClosedFurnace and AC
Direct Link To This Post Topic: Furnace and AC
    Posted: 22 May 2013 at 6:45pm
Congrats on the repair.
gappman, the furnace and the A/C are both very loud IMO.  Most people use an electric heater when they have hookups so they don't have to listen to the furnace.
Seanl View Drop Down
Direct Link To This Post Posted: 22 May 2013 at 6:22am
Originally posted by gappman
That's awesome! Congrats! Thumbs Up
One question about your furnace. Is it loud when it cycles on and off? The blower fan, is it noisy like a hair dryer?
Gary
One word yes. Doesn't bother me but some people don't like it.
gappman View Drop Down
Direct Link To This Post Posted: 22 May 2013 at 12:24am
Gary
Gary Piazza
www.garypiazza.com
yellowstonestu View Drop Down
Direct Link To This Post Posted: 21 May 2013 at 11:21pm
Found the problem!  It was a faulty thermostat - new thermostat and the furnace works like a charm!!
Thanks to everyone for their thoughts, advice and support.
Yellowstonestu & Bela the Vizsla
2008 Toyota FJ
2015 RPod 179 (Pod #2)
Direct Link To This Post Posted: 16 May 2013 at 9:50pm
Yes, very odd.  Even with no propane you are right the fan should immediately turn on - on 120 or 12 volts.
Direct Link To This Post Posted: 16 May 2013 at 7:43pm
Totally agree with elec htr if one needs it for an extended period of time. I usually sleep cool, then like to heat for a short period in the a.m. just to knock the chill down.
Yes, I had cooked on the stove, H2O htr was on elec this time, as was the fridge.  I believe the lines had been fairly well purged of any air.  Also, the blower should turn on immediately (it does on batt power), but no fan, no click-click-click of igniter trying to ignite.
Still a mystery to me.
Thanks for your ideas, though!!
2008 Toyota FJ
Direct Link To This Post Posted: 16 May 2013 at 2:55pm
OK.. gas was turned on...? Bottles not empty??
Did you use the cook top or water heater on gas?
If it has been a while since any gas appliance has been used, then the lines may need to purge.. the heater is usually the farthest away from the supply, and takes the longest. Also, unlike the cook top, if it doesn't ignite in a set period, it stops trying.. whereas you can stand there with the cook top  knob on and let the line purge until it ignites.. or you burn your fingers holding a match.. (I use one of those long bic lighter thingies) The gas water heater will also error out and stop trying if no flame is detected in a certain amount of time.. (so what I am saying is.. go out to the camper and light the burners.. then try to light off the furnace...)
(BTW, almost no one uses the propane heat if they have hookups.. we use a small ceramic heater, quieter, and cheaper)
Direct Link To This Post Posted: 16 May 2013 at 2:39pm
All good points!  No, I didn't disconnect the battery. Yes, the lights, fantastic fan and fridge all worked on 12 volts.  Just the furnace fan didn't work and the furnace didn't ignite.  Ketelsen campers in Wheatridge, CO suggested that the converter fuse may be blown, but I didn't discover that either.
Guess I will take it into Ketelsen and see if they can figure anything out!
Thanks for all the great input!  This site rocks!!
2008 Toyota FJ
Direct Link To This Post Posted: 16 May 2013 at 8:33am
While the furnace only works on 12v, it has 12v ANYTIME the trailer has 110v, unless there is a problem with both the converter/charger and the battery.
The question is, did all the other 12v stuff work? Lights, water pump, Fantastic Fan, Fridge on 12v?
Direct Link To This Post Posted: 16 May 2013 at 12:00am
Yes the furnace only workes on 12 volts.
