  New Posts New Posts RSS Feed: Tire inflation for 181G and 182G owners
Topic ClosedTire inflation for 181G and 182G owners
Our-pod View Drop Down
Direct Link To This Post Topic: Tire inflation for 181G and 182G owners
    Posted: 04 Feb 2013 at 10:51am
Didn't blow the fuse on the Rpod.  Not sure about cars.
danthoman View Drop Down
Direct Link To This Post Posted: 02 Feb 2013 at 8:48am
A lot of reviewers have a problem with the viair compressor blowing the fuse.  Has anyone had this problem or is it just a problem with smaller cars and their lighter gauge electrical systems?
Linda and Dan
Calley the golden retriever
R-pod 177 and a Tundra 8 cyl
Yak View Drop Down
Direct Link To This Post Posted: 01 Feb 2013 at 9:35pm
I've been plugging radials for 40 years, no issues, the best way is a plug/patch but it requires a tire dismount.
Direct Link To This Post Posted: 29 Jan 2013 at 9:15pm
Techntrek - like you I have messed with the cheaper models as well. This one seems significantly better in terms of inflation. I'm not crazy about the threaded fitting to the valve stem on mine - it doesn't swivel as easy as it should. Still better than anything else I've tried.
My tires were about 10psi low last weekend. It took maybe 10 seconds for each tire to inflate.
From my motorcycle days, I became used to carrying a plug kit. I now do that with my cars and trailers as well. I also carry some green slime sealant. It's non-flammable and can get you moving fast, allowing you to repair later in a safer or more convenient location.
Direct Link To This Post Posted: 29 Jan 2013 at 2:57pm
The ones I've used for years say they are good for radials, and I've permanently patched several tires with them with no leaks.
Direct Link To This Post Posted: 29 Jan 2013 at 10:59am
Thanks Seanl.  I looked on the internet and as usual the answers are contradictory.  Firestone says to patch and plug; michelin says to patch only and other manufactures say to plug only. Some say to remove the tire and use a spreader while others say not to use a spreader because it deforms the tire when patched.  The tire guy I buy from says they only patch tires (I just called) but I have seen them plug tires.  This link seems to make some sense:
http://autorepair.about.com/library/faqs/bl028a.htm
Linda and Dan
Seanl View Drop Down
Direct Link To This Post Posted: 29 Jan 2013 at 10:25am
Originally posted by danthoman
techntrek - do the plugs work on radial tires?  I always heard that radials needed to be patched rather than plugged.
I am not Techntrek but I will take a stab at this. As I have heard it you should not use plugs on steel belted tires because the belts could cut through the plug. That being said I am sure it would work in an emergency.
Direct Link To This Post Posted: 29 Jan 2013 at 9:22am
Linda and Dan
Direct Link To This Post Posted: 28 Jan 2013 at 7:49pm
I took a look at that air compressor yesterday, expensive for a 12 volt model but after years of dealing with the bargain models I think I'll look for one like that next time I need to replace one.  I keep an air compressor and tire plug kit in 2 of our 3 vehicles.  The only time I've had to actually change a tire was when the hole was way too big for the plug.
Direct Link To This Post Posted: 27 Jan 2013 at 7:11pm
Thanks!
Here's the link to the one I bought.
Edit: made it a clickable link - Techntrek
