  New Posts New Posts RSS Feed: dinette bench ends
Topic Closeddinette bench ends
Keith-N-Dar View Drop Down
Direct Link To This Post Topic: dinette bench ends
    Posted: 15 Jan 2013 at 10:46am
I left mine at original height, but replaced the hardware with screws and nuts.  I put washers on them and they stay put well.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
wagnert View Drop Down
Direct Link To This Post Posted: 14 Jan 2013 at 11:02pm
I think you will like the lowered bench end pieces. I also considered just removing then, but lowering them gives the dinette a finished look. The screws Forest River uses for the original install are a bit wimpy. The heavier stainless steel screws give a very secure attachment.
Happy RVing!
Tom Wagner
Tom Wagner
2012 R-Pod 177
2003 Toyota Sienna
LarryK View Drop Down
Direct Link To This Post Posted: 14 Jan 2013 at 10:24pm
We've noticed the end caps being uncomfortable, just as you have mentioned.  One of ours came off and I planned to remove the other, but your idea of lowering them may be what I will do.  Thanks for posting the solution. I also planned to remove those other things under the table.
2012 R Pod 177
2006 Toyota Tundra Access Cab
4.7 Liter V8
Direct Link To This Post Posted: 13 Jan 2013 at 8:21pm
There was only one of those things on mine, and I removed it right away after getting several gashes.  No issues with the table shifting on ours, either.
Direct Link To This Post Posted: 13 Jan 2013 at 12:06am
I removed the dinette bench ends, and lowered them about 1 1/2" so that you can sit on the end of the bench and face the rear of the R-Pod (for example, to tie your shoes). Or sit on the end and swing your legs in to sit at dinette.  There is still enough endcap to hold the seat cushions. Makes a huge comfort difference not having the end cap press into your thighs.  I used 1 1/4" #8 stainless wood screws (which are heavier than the originals) with a shoulder-shaped finishing washer. Stainless looks good. Did not worry about covering the screws heads. There is plenty of wood in the benches when you lower the endcaps to hold the screws. I used three screws on each in addition to lowering and re-attaching the L-bracket at the top of the endcap. Total effect was much sturdier than the original install.
Also I removed the sockets that are along the front of each bench to hold the table when in the down position. We eliminated them completely and have not had and issues with the table moving while underway. Got some annoying gashes from those sockets when the were there. We always connect the strap that is acorss the top of the table in the down position.
It's a quick mod worth doing. Nice improvement.
Tom Wagner
Tom Wagner
2012 R-Pod 177
2003 Toyota Sienna
Robwid View Drop Down
Direct Link To This Post Posted: 26 Sep 2012 at 11:17pm
I've had the same issue with the one closest to the door.  I used a long wood screw on the left and a bolt on the right.  Even though the screws had started to pull out of the wall after re-attaching with the new hardware the wall screws are holding just fine.
Rob
2012 HRE 177
2010 Toyota Tacoma
Paige View Drop Down
Direct Link To This Post Posted: 26 Sep 2012 at 12:08pm
Wow, I was impressed when I saw the 2013 version of the end caps,,as our RPod is a 2011. Guess no matter what year,,,they are flimsy. Ours are also uncomfortable,,want to replace them with more paddding,,,or possibly wooden molding.
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
coopercdrkey View Drop Down
Direct Link To This Post Posted: 25 Sep 2012 at 4:54pm
I agree that they are less than sturdy.
I intend to back them up with some 6 mm Okume plywood scraps from my current sailboat build.  I'm not so much concerned that the cushions will wander as I am with the cosmetics of the end caps.  They match several other trim pieces of our RP 177.  I'd hate to see them go....
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 25 Sep 2012 at 4:20pm
I replaced the wood screws with bolts, washers on the inside and nuts.  No more trouble.  The fabric covered caps on the screws pop off easily with a flat screwdriver and pop right on.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
The one on my 171 disintegrated almost right away, I just removed it.  No issues with the cusions moving.
