Topic: What is your ideal inside Pod temperature? Posted: 12 Sep 2012 at 12:18pm |
Originally posted by Podsible Dream
I was wondering if the reason for the oversized AC units was to provide sufficient cooling for trailers in exposed places. ... |
I agree for most campers. For example, a large popup in full sun on a hot day. No insulation (maybe some in the roof), lots of holes where all the slideouts are, and tenting that basically has a negative R value since it allows air to pass through. Our popup had a 15000 btu unit and could at least keep the main part of the camper cool on hot days in direct sun. The rest of the time it could freeze you out.
The pods on the other hand are about the best possible situation. Good insulation, enclosed, few holes, etc. Even the ones with tent-ends are 10 times better than a popup.
Seanl
Posted: 12 Sep 2012 at 9:52am |
A creative way to get the humidity out but not be frozen, not that it is energy efficient.
not very no and the AC worked better that the heater so it had a hard time keeping up. I had to do it though because it was raining out and it was so humid inside that we were getting condensation but if I turned on the air alone we would have needed parkas.
Podsible Dream
Posted: 12 Sep 2012 at 7:49am |
I was wondering if the reason for the oversized AC units was to provide sufficient cooling for trailers in exposed places. Places lik AZ, WA, Montana, IA, midwest or centrel US (west of the Alleghenies) and even Midwestern Canada, where tree cover isn't as common as it is here in the east and a camper is very exposed to the sun. The heat load must be intense compared to our common experience with room AC units -where we are cooling one room of a house with usually R30 in the ceiling ( or another room above) and R15 or better in the walls and common walls with other interior rooms, not an isolated box exposed on all sides, including the bottom.
Just a thought...
Chris and Walt
'10 RP-171 'Free Spirit'
Posted: 11 Sep 2012 at 8:35pm |
Bill-GA
Posted: 11 Sep 2012 at 8:28pm |
The tent-end pods probably don't have the humidity issue since they can "breathe", like popups. |
I have a 176T and what I found very effective for ventilation and humid air was to crack the tent windows (zippers) for a 2-3 inch openning and then turn the bathroom vent on. HOWEVER, I would usually get up 1-2 AM and turn off the fan because it got cooler.
What would REALLY BE NICE is a TIMER ON THE BATHROOM FAN. FR are you listening? Has anyone done this? Any suggestions?
I haven't camped in a cold season yet ... And I'm not sure a tent would release much moisture unless the windows were open - same as in a non-tent RP.
Forgot to mention that when the Pod was hot, setting the AC on AUTO and at a specific temp, when the temp is reached, the AC shuts off ... I didn't need to get up and turn it off as the morning air was now cooler.
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
Seanl
Posted: 11 Sep 2012 at 7:54pm |
Originally posted by Mike_n_Deb
The A/C is so oversized for the space that it won't run long enough to remove the humidity created by 4 people if it is kept warmer. |
That's an interesting comment that has also crossed my mind. Why is it such an oversized unit?
Surely something in the 5k to 7k Btu range would be adequate and more economical, in initial cost, electricity, and weight. Might also allow realistic use of a single 2kw generator.
.......Mike |
Yes all of the 5K Btu units for RVs are wall mounts which will not work on the RPod. Once I ran and electric heater and the air conditioner to get all of the moisture out of the air. Can't do that on a generator.
Posted: 11 Sep 2012 at 6:40pm |
5000 btu would probably be the best size, considering it is only about 100 square feet and very well insulated. I think the problem is the only room to mount an A/C on the pod is on the ceiling, and 11500 btu is the smallest they make them. I've gone round and round on another thread considering options that would work in about the 5000 btu size.
Mike_n_Deb
Posted: 11 Sep 2012 at 5:46pm |
.......Mike
this_is_nascar
Posted: 10 Sep 2012 at 1:24pm |
I keep my campers and my home at 69-degrees all year long, whether that means we turn on the AC or Heater, it doesn't matter. Whatever's required to maintain 69.
"Ray & Connie"
- 2017 R-Pod RP-180
Goose
Posted: 10 Sep 2012 at 11:23am |
77 day and night when we stay in AZ. Anything lower is to cold. Goose
