  New Posts New Posts RSS Feed: water heater
Topic Closedwater heater
Direct Link To This Post Topic: water heater
    Posted: 23 May 2012 at 9:30am
The valves should be turned as you see them to use the water heater. One line is cold water in, the other is hot (hopefully) water out.
During winterization you bypass the water heater by turning all three valves 90 degrees, creating a "loop" before the water heater, so it doesn't have to be filled with anti freeze. You just drain the water heater by removing the anode.
Then, when winter is over, you turn them all back again. Replace anode, rinse with potable H2O, sterilize plumbing system, camp.
Repeat next year.
Or, maybe you don't, in Florida. Wink
My dad has been RV'ing for 40 years, never winterized yet. Central valley of California stays above freezing..
blissful View Drop Down
Direct Link To This Post Posted: 22 May 2012 at 6:09pm
Marwayne,
Thanks for quick response.  Mine does not look like that.  It's a 2011 171.  Am I to assume that the red line is the hot water and that the white line is cold.  The knob in the middle of mine is black...is that the one that should be turned facing in both directions?
BLISSFUL
Direct Link To This Post Posted: 22 May 2012 at 4:25pm
That shows the "in season" configuration - the knobs on top and bottom are parallel to the tubing, the one in the middle is perpendicular.  The winterization configuration is exactly opposite.
Direct Link To This Post Posted: 22 May 2012 at 3:48pm
Pics. of waterheater,
Direct Link To This Post Posted: 22 May 2012 at 3:22pm
Easy to open under the bed for access to water heater so decided to make certain that all was o.k. to run heater.  Did not see three valves as mentioned in an answer to my question.  Only saw one white valve which was parallel to hose and one black knob.  Does anyone have a picture of the water heater enclosure?
Blissful
