  New Posts New Posts RSS Feed: plastic container
Topic Closedplastic container
Footslogger03 View Drop Down
Direct Link To This Post Topic: plastic container
    Posted: 05 Apr 2013 at 9:47pm
That's the one   ...thanks for finding it !!
MJ
Direct Link To This Post Posted: 05 Apr 2013 at 8:01pm
Originally posted by Footslogger03
I essentially did the same thing. Pics are posted here on this site but couldn't locate the post ???
Found it:
http://www.rpod-owners.com/forum_posts.asp?TID=2881&PID=27275&title=sewer-hose-tube
Direct Link To This Post Posted: 05 Apr 2013 at 8:32am
I got the e-mail address of the company who made the factory tube. I bought the 48" length tube. I went to ACE Hardware and bought a piece of right angle (steel). Had to drill a few holes but got the new 48" tube mounted directly under the battery area and about even with the front edge of the Pod. Now I have the shorter factory tube that holds the shorter section of drain hose and the 48" tube that holds the 15" hose plus a clear connector/adapter so that I know when the tank is running "clear".
MJ
We got one of those last year.. I never knew poop could be so interesting.. LOL
I do like the idea of adding a second, longer container.
Direct Link To This Post Posted: 04 Apr 2013 at 10:16pm
MJ
dsmiths View Drop Down
Direct Link To This Post Posted: 04 Apr 2013 at 9:23pm
Camper Bob is right. you can leave the factory tube and mount the new one between the frame rails about one foot back from the front frame rail. be careful of gas lines and electrical wiring. I removed the short tube to save weight. the mounting brackets on the replacement tube are a little short to mount on the center of the side frame rails. I built spacers to go between the factory frame rails and the mounting ears on the replacement tube. drill pilot holes and then use self tapping metal screws.
Dane and Donna Smith
2011 RP-172
lift kit
Camper Bob View Drop Down
Direct Link To This Post Posted: 04 Apr 2013 at 8:46am
To answer your question, yes.  We have both tubes installed.  I use the shorter one for my rubber coated fishermans gloves for working with the sanitation items.  Hoses, etc.  Had the longer one installed just behind the original one from the factory.  We are heading out for our first 2013 trip in 3 weeks.  Counting the minutes.  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
coopercdrkey View Drop Down
Direct Link To This Post Posted: 04 Apr 2013 at 6:49am
Thanks for the tip!
Just curious, can you install the new tube and still keep the factory installed one?  I ask because I use the
stock tube to store a couple of hitch-related items, and it is quite handy for that purpose.
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 03 Apr 2013 at 10:05pm
cooperdcrkey, I googled the address on the end of my factory tube and the company makes a replacement tube for the R pod that will hold the 15 foot hose and ends, I can't remember the price but I think it was under 40 bucks. I installed the new one about 1 foot back from the front of the pod, it works perfect for the longer dump tube.
2011 RP-172
lift kit
Goose View Drop Down
Direct Link To This Post Posted: 03 Apr 2013 at 5:13pm
coopercdrkey, I second you on marwayne!!    Goose
Direct Link To This Post Posted: 03 Apr 2013 at 4:34pm
Gotta' LOL at marwane!  He's our most innovative 'Podder with consummate cabinet making skills-  Best
on the forum!  (And I state that with sincerity and admiration, having cobbled a few cabinets in my time!)
If there's a cubic centimeter of available space in his 'Pod, it's put to work!
Good job, sir, and damn the Tupperware!  Full speed ahead!
(And I agree-  If you want it done right, do it yourself!)
Bob and Joyce
RP 177 "Key Pod"
