  New Posts New Posts RSS Feed: black water drain hose
Topic Closedblack water drain hose
pmjensen View Drop Down
Direct Link To This Post Topic: black water drain hose
    Posted: 08 Nov 2011 at 1:49pm
I put one on our 176 under the pass through. I sprayed it with black truck bed paint from Walmart.  Minimal time & effort to construct.
Happy Podding
2011 R-176 Nuestro Pod
2014 Silverado
harleyguy1 View Drop Down
Direct Link To This Post Posted: 07 Nov 2011 at 7:39pm
Tidalwave is correct, the 4 inch pvc fence post will not work, the next size up (4 3/4-5) works great, even has end caps to fit.  I have one installed under my battery and painted it black, it looks nice!
Marshal
2011 R-177
Longview, Tx
Direct Link To This Post Posted: 07 Nov 2011 at 1:15pm
Still on my to-do list, thanks for the pointers.
Tidalwave4455 View Drop Down
Direct Link To This Post Posted: 07 Nov 2011 at 8:42am
If you replace your hose carrier with a pvc 'fence post' determine whether or not a 4inch post will fit the hose. A 4 inch diameter tube will not fit the drain hose if you have plastic fittings on the ends of the hose. After following the suggestions of several forum posts, I was going to use a 4 inch diameter plastic post.  The drain hose is 4 inches.  I also have plastic end fittings on the hose to connect to the drain gate valve and an elbow for the other end. A 4 inch tube wouldn't hold the hose.  I found a post that was slightly larger (about 5 inches).  Now the hose will fit even with the plastic end fittings.
TerryM View Drop Down
Direct Link To This Post Posted: 06 Nov 2011 at 1:54pm
I put mine in a lidded plastic bin and store it in the back pass through compartment.  Some day I'll get around to using the fence post mod.
Terry
kymooses View Drop Down
Direct Link To This Post Posted: 06 Nov 2011 at 11:11am
Like some people I replaced the factory holder with one made from PVC fence post.  Much happier with that, and it took very little time or materials.
tpierce220 View Drop Down
Direct Link To This Post Posted: 06 Nov 2011 at 9:34am
The standard tube will fit a 10' hose, but it won't fit a 20' one or 2 10's.  I know that people have put PVC piping to store the hose.  I have not; I do store it in the pass through where the spare tire is at but close both ends so that odors are locked into the hose as much as possible.
dsmiths View Drop Down
Direct Link To This Post Posted: 06 Nov 2011 at 9:13am
Will a longer black/grey water dump hose fit in the exsisting tube or will I need to change the tube also ?
Dane and Donna Smith
2011 RP-172
lift kit
