  New Posts New Posts RSS Feed: Dinette screws in 180
hank*pod View Drop Down
Post Options Post Options   Quote hank*pod Quote  Post ReplyReply Direct Link To This Post Topic: Dinette screws in 180
    Posted: 06 Nov 2022 at 8:04am
If the women don't find you handsome they should at least find you handy.
campman View Drop Down
Post Options Post Options   Quote campman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2022 at 9:02am
If screwing into the light wood pieces, I would recommend marking and pre-drilling the holes to prevent them from splitting when the wood screws are installed.
There are a lot of Red Green fans out there, which is great! I think we can all use a bit more humour in our day.
Andy
Andy and Laurie
'21 RP192
Red-Green
Tulefog View Drop Down
Post Options Post Options   Quote Tulefog Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2022 at 12:22am
Thanks the L brackets may be the next addition. I will check out the table legs too.
Keep your stick on the ice(we watch Red Green a lot).
2021 Rpod 180 2006 Ridgeline
Post Options Post Options   Quote campman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2022 at 10:07am
Nice colour match, the screws look like they belong.
I had to do similar work on the door side dinette seat as well.
I needed to redo the floor screws, as the ones they put in were screwed into holes in the floor that were too large.
As well I needed to add L shaped brackets to reinforce the horizontal wood structure inside the seat at all the accessible corners, top and bottom.
Now we can use the seat without it wobbling.
I still need to replace the plastic mounts for the steel tubes that the table sits on. Junk light weight plastic.
Have a good one,
Andy
Andy and Laurie
'21 RP192
Red-Green
Post Options Post Options   Quote Tulefog Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 12:58pm
The sides of the dinette in our 180 don't feel too secure, I noticed they added three screws on each side on the new 180. Very carefully I drilled pilot holes in my dinette seat sides and put #8-1" lath screws
into support frame and it seemed to make the sides more secure, without reducing integrity. My interior is white, the new 180 was dark brown it is a little hard to see three screws in picture.
