Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
![]() Posted: 28 Jul 2020 at 5:33pm |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6438 |
Also, now that you have it back in place, don't put things in the sink while you are traveling. No sense putting even more stress on those screws.
The problem over the long run is the particle board counter. Fasteners don't hold well under stress and possible moisture in that stuff. One of my winter projects will to preemptively replace our under mounted sink with a surface mount. The hard part is finding a decent sink to fit. Making a sink cover is pretty easy.
GMflyfish ![]() Newbie ![]() Joined: 26 Jul 2020 Location: Inverness FL Online Status: Offline Posts: 4 |
Got some new screws and washers - sink is back in place - I think the washers will add a little more stability. I will keep an eye on how tight they are and tighten them when needed. The back screw was the toughest
GMfkyfish
+1
Assuming its the undermount sink there have been tons of problems, you can do a search on the forum for a variety of fixes.
Basically, it is a poor design choice to try to hold a sink from below up into fiberboard. Screws don't hold in that stuff, and if water gets in there forget it. My recommendation is to remove the sink and drop it or another one in from above so it gets supported properly.
I have used the trailer for the past three weeks and the sink fell down. I am going to re Caulk it and add some washers to the screws to get a little more coverage of the sink. Anyone else have this problem or any other ideas for a fix?
