  New Posts New Posts RSS Feed: Black tank flush out hook up
Topic ClosedBlack tank flush out hook up
DavMar View Drop Down
Direct Link To This Post Topic: Black tank flush out hook up
    Posted: 19 Oct 2018 at 5:30pm
If you want I suppose one can always hook up your air hose or pump RV antifreeze into your black water flush. Though I a cup or two of antifreeze flushed down into your black water tank I believe is all you need.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
mcarter View Drop Down
Direct Link To This Post Posted: 19 Oct 2018 at 4:28pm
Shane, I don't think so. I do agree with Furpod it is a gravity drain, and no water should rest in it. It is inside the Pod, mine is in the shower wall below the sink.
Shane View Drop Down
Direct Link To This Post Posted: 19 Oct 2018 at 10:55am
Yes mine is factory installed and yes it is in working order, use it every time when I dump black tank. If there is a possibility of it freezing is it possible to push in the valve manually and try to send some anti-freeze through that line?
ENGINE 55,TRUCK 44,BATALLION 12
Direct Link To This Post Posted: 18 Oct 2018 at 12:26pm
Couple of comments.
Mine was also installed wrong so I relocated it to the drivers side near the blacktank. It has a one way valve in the line, that in fact did freeze last year, I'm sure because it does not gravity drain well. The reasons I chose to relocate - the factory installed valve is behind the bathroom sink, too much hassle to get to, and I never liked the flush on the curbside.
I do use compressed air and I blow out the flush line. NOW
Happy Tripping View Drop Down
Direct Link To This Post Posted: 18 Oct 2018 at 11:45am
Just as a parenthesis - I assume that you have shown that it is working??
The reason I ask is that ours was installed at the factory incorrectly and never worked.
It should be a straight through hook up with a valve to prevent backflow.
Direct Link To This Post Posted: 18 Oct 2018 at 11:27am
It's a straight gravity feed to the tank.So far as I can recall, no one has ever had a issue with it freezing.
Direct Link To This Post Posted: 18 Oct 2018 at 11:15am
I should mention I do not use a compressor to flush out my system.
Direct Link To This Post Posted: 18 Oct 2018 at 11:14am
I have already did my winterization on my pod, except for the black tank flush hook up, I tried to flow antifreeze through it but it would not flow through. How do I make sure there is no water in this line. Everything else is all good.
