wthoms2000 ![]() Groupie ![]() ![]() Joined: 06 May 2017 Location: Costa Mesa, CA Online Status: Offline Posts: 45 |
![]() Posted: 25 Jul 2018 at 12:39pm |
Same as Crankster78:
https://m.facebook.com/?_rdr#!/photo.php?fbid=10217417197960829&id=1201177476&set=p.10217417197960829&source=47 Actually is ten minutes! |
Porta Poddy
Wil and Luz, Orange County, CA 2017.5 179 HRE 2021 Ranger XLT FX4 REDARC Brake Controller |
crankster78 ![]() Senior Member ![]() Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Greetings Nice job. What I did is took a piece of strap, removed a bolt from the valve, installed the strap on the bolt, and drilled a couple of self taping bolts into the frame. Tightened the bolt back up. Took about 10 minutes. Crankster78
Crankster 78 R-179 2015
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
Remember, these hangars go by the ID of the pipe (not the OD). So the 3-1/2" (OD) black water pipe is actually a 3" (ID) hangar.
Ben Herman ![]() Senior Member ![]() Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 359 |
Nice job! Where do you get the clevis hangers?
After seeing the results of what happens if the brackets for either the black or gray water tank drains fails, I decided to invest in a little preventative measure. I call this "belt and suspenders", as if one bracket fails, there will be a second "just in case". The parts I used are all stainless except for the clevis hangars, which are epoxy coated. I could have used stainless clevis hangars, but the 3" one is $5 in epoxy coated, and $30 in stainless. In this particular instance, I chose overkill instead of massive overkill. All of the nuts are stainless nylock nuts. Black water hangar: ![]() Gray water hangar: ![]() |
