  New Posts New Posts RSS Feed: Fantastic Fan Failure
Topic ClosedFantastic Fan Failure
MoPod View Drop Down
Direct Link To This Post Topic: Fantastic Fan Failure
    Posted: 16 Jun 2019 at 5:48pm
Additional troubleshooting seems to indicate the culprit is the 3-way switch on the fan.  Ordered one from Amazon and hope this is the fix!
Bill & Nancy
2015 RPod 179
Previously 2010 RPod 176
2014 Explorer Sport
mcarter View Drop Down
Direct Link To This Post Posted: 14 Jun 2019 at 6:07pm
My issue was the open/close vent switch sticking. The speed switch was working.
Direct Link To This Post Posted: 13 Jun 2019 at 5:57pm
Sounds like maybe a bad switch. I assume you've worked the switch a few times to see if that removed any corrosion and it begins to work again?
if not then I'd next check to see if you're getting 12V to the switch but not out of the switch.  I'm not sure how the fan is wired but can you get to the wire connections at the switch?  If not you might need to cut the wires, test using a multimeter, then later reconnect and insulate them.
Direct Link To This Post Posted: 13 Jun 2019 at 2:41pm
Okay, my fan quit working this week while turning up from low to medium speed.  Fuse in box good.  In-line fuse good.  Nipple is up and manually pushing up and allowing it to come back up (while on ladder outside) makes no difference.  No other 12V system problems.
Any suggestions for next step?
Bill & Nancy
2015 RPod 179
2014 Explorer Sport
henryv View Drop Down
Direct Link To This Post Posted: 20 Jan 2018 at 3:51pm
It was the fuse. Now I don't have to worry about nipples!
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 19 Jan 2018 at 6:20pm
I just replaced what you're calling that nipple.  I found the part on line somewhere for about $7 (+ about $10 shipping).  I got at it from the top, outside.  Pretty easy and obvious how to fix it.  But... I was able ti recondition the old switch with a little oil.  Now I have a spare,  If you end up going this route, it's easy to bypass the switch to see if the fan runs.
If this is the first time it's happening, a little WD-40 followed by a drop of oil might take care of it without removing it.  Check the fuses, etc., first.
TT
FJ Cruiser
Direct Link To This Post Posted: 19 Jan 2018 at 6:08pm
Originally posted by henryv
Assuming it is the nipple how do I correct it?
Depending on the size and flexibility of your hands, with the fan off, raise the lid, remove the screen and reach up and through the fan mount to the outside, and feel around for the nipple, jiggle etc and see if it moves up and down. It's towards the hinge side, outside edge, where the lid lip comes down.. You can also lean a 6 foot ladder against the pod, even with the FF, and open the lid from the inside, then just climb up, and you can see it there.
BUT, I would test the fuses first, the connections, and check for 12v at the fan first.. those are easy to do and rule out.
Direct Link To This Post Posted: 19 Jan 2018 at 4:48pm
Direct Link To This Post Posted: 19 Jan 2018 at 4:12pm
It could be the fuse in the fan, it could be the fuse in the distribution box. It could be a loose wire, a bad switch, a bad motor, It could be the little nipple on top that tells the motor the lid is open, is stuck in the down position.
If you check all of those, and don't find the issue, call FF. In my experience, they have GREAT customer service. They sent me parts gratis for a 3 year old fan, that I told them I broke while upgrading the fan.
I wouldn't hesitate for minute to call them again.
BTW, this time of year, my bet is on the nipple.
TheBum View Drop Down
Direct Link To This Post Posted: 19 Jan 2018 at 3:36pm
Did you check the fuse box? If there's a red LED lit next to a fuse, then that fuse is burned out.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
