Page 123> |
mjh203 ![]() Newbie ![]() Joined: 10 Jul 2016 Location: Colorado Online Status: Offline Posts: 19 |
![]() Posted: 14 Aug 2016 at 9:50am |
I am looking for recommendations for a power jack for my R-Pod 178. Also, this is probably a question I should know the answer too but I don't so... If I have a power jack and my battery goes dead, will plugging the 7 way into my truck instantly give it enough juice to operate the jack?
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1454 |
Maybe this isn't the solution for everyone, but I replaced the crank on my stock jack with a hex nut the same size as the shafts on the stabilizer jacks. I use an 18v cordless drill for both now. Less work and a lot less expense than buying a power jack. The drill has plenty of power for cranking the trailer up or down quite a few times.
TT |
FJ Cruiser |
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
That's a good tip!
+1.
But if you decide to get a power jack I use a Husky brand jack with my current trailer. Get one that is rated at least 3000 pounds if you have a WDH since you will be lifting the rear of the TV, too. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6429 |
I purchased the Jack Quick model for our R179. The link will take you to pictures of it installed. It has a 3650 lb capacity and costs $111.61 on Amazon. It is a Prime item if you are a member.
Thanks for the info!
I followed StephenH's lead and purchased the the Jack Quick 3500 JQ-3500B 12v electric tongue jack. It is still on Amazon for the $111.61. We have the Amazon Prime so we got free shipping with 2 day delivery.It has the 3650 pound capacity. It was a very easy install and will make set up quite a bit easier.
Thanks StephenH for the info! |
I am glad you found the information useful.
Bovine0001 ![]() Groupie ![]() Joined: 24 May 2016 Online Status: Offline Posts: 40 |
how did you do that? My crank does not simply come off. |
2014 Rpod 178
Mods in Order: 1: Added USB charging port 2: Added Spigot at Fresh Water to make easy empty 3: Solar Panel 4: Cut dinette bench panel to improve access underneath |
JScottHouse ![]() Newbie ![]() ![]() Joined: 09 Aug 2016 Location: Maidens VA Online Status: Offline Posts: 12 |
Yes, plugging in the tow vehicle will provide the power for the jack .... Provided the seven way is wired with a charge wire.
2016 RP-180
2013 Ford Explorer 4WD |
Page 123> |
