  New Posts New Posts RSS Feed: Can't flush black tank
Topic ClosedCan't flush black tank
Bovine0001 View Drop Down
Direct Link To This Post Topic: Can't flush black tank
    Posted: 30 Jun 2016 at 11:43pm
So my owners manual doesn't really tell me how to use the sewer tank flush. I opened up the black tank, hooked up water to the flush connection and turned on the water. Nothing came out. I am now pushing water through my toilet. Can we do better?
Thanks
2014 Rpod 178
Mods in Order:
1: Added USB charging port
2: Added Spigot at Fresh Water to make easy empty
3: Solar Panel
4: Cut dinette bench panel to improve access underneath
trixilou View Drop Down
Direct Link To This Post Posted: 01 Jul 2016 at 9:00am
There should be a little handle on the side of the pipe, near the end, that you pull out AFTER you've hooked up your drain hose.  Have you done that yet?
Direct Link To This Post Posted: 01 Jul 2016 at 9:26am
something other than the blade valve for the black tank?  This is open.
2014 Rpod 178
Mods in Order:
3: Solar Panel
JandL View Drop Down
Direct Link To This Post Posted: 01 Jul 2016 at 9:40am
There has been post from others that had the same problem that when you hook your garden hose up to the black water tank flush that nothing comes out. It turns out that the inline check valve is installed backwards and so no water can flow to the black tank.
http://www.rpod-owners.com/forum_posts.asp?TID=7346&KW=black+water+flush&PID=76955&title=black-water-flush-location#76955
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 01 Jul 2016 at 10:12am
What?!? That's nuts!
Thanks for the link.
2014 Rpod 178
Mods in Order:
3: Solar Panel
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 01 Jul 2016 at 4:37pm
it is a human mistake, and easily fixed.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Dr. GREG SMITH View Drop Down
Direct Link To This Post Posted: 02 Jul 2016 at 6:43am
I have the same issue. can the inline check valve be fixed by a techno dummy, or should I have the dealer fix?
Direct Link To This Post Posted: 02 Jul 2016 at 7:18am
If getting to the dealer is convenient and it can be scheduled quickly, then it would be good to let the dealer do it. If, on the other hand, the dealer is a distance away and they tell you that it can't be done for several weeks, and you can handle simple tools, then by all means, do it yourself. I did not have the problem, but others have said that it is a simple job. The hardest part is getting to it.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 02 Jul 2016 at 7:34am
There was also a reported issue where the hose was severely kinked, not allowing water to flow.
"Ray & Connie"
- 2017 R-Pod RP-180
Westgl View Drop Down
Direct Link To This Post Posted: 02 Jul 2016 at 1:19pm
You would think FR would have these down pat by now and at least do enough training to keep the quality up to a higher or somewhat high standard.
2010 RAV4 V6
2017 RPOD 179 Hood River Edition
Dual 6 volt Batts
Dual propane Tanks
Batt Disconnect
Bed leg extension
Dinette modification
Renogy 100w solar
Motorcycles several currently
