  New Posts New Posts RSS Feed: Battery disconnect
Topic ClosedBattery disconnect
Idaklee View Drop Down
Direct Link To This Post Topic: Battery disconnect
    Posted: 09 Mar 2016 at 11:22am
Please advise. Dealer says this is a $30 part and since my battery sits outside on the hitch frame. The knob needs to be attached to the frame. Better way ??
Thanks in advance.
Marcia from MN
13 177 R Pod
06 Dodge Grand Caravan
Max, Gracie & Greta
Direct Link To This Post Posted: 09 Mar 2016 at 11:41am
I put mine right on the battery box. It can actually be anywhere between the battery and the distribution box. Several have mounted them inside. Depending on the switch, $30 is probably mid pack..
CharlieM View Drop Down
Direct Link To This Post Posted: 09 Mar 2016 at 11:55am
Thanks in advance.
Also available is the zero cost option of just physically disconnecting one side of the battery. Works great, but less convenient. Otherwise follow Furpod's solution.
Direct Link To This Post Posted: 09 Mar 2016 at 12:33pm
3rd option that I used with our pod: Add a weatherproof fuse holder so it sticks outside of the battery box. Insert 30 amp fuse, pull fuse to disconnect.
Direct Link To This Post Posted: 09 Mar 2016 at 12:34pm
Hmmmmm..thanks for the suggestion. I'll give it a try and see how difficult it is for me to get the cover off! My Aliner had the battery under the bed and was very difficult to get at it.
Marcia from MN
13 177 R Pod
Max, Gracie & Greta
Direct Link To This Post Posted: 09 Mar 2016 at 12:40pm
Thanks everyone! I love this forum. Not only is everyone incredibly helpful, it's much easier to find the posts!!
Marcia from MN
13 177 R Pod
Max, Gracie & Greta
Direct Link To This Post Posted: 09 Mar 2016 at 1:28pm
Caution! If you are going to disconnect the battery either by disconnecting the terminal or by using a switch, make sure it is the NEGATIVE (-) terminal. I just finished my installation.
Direct Link To This Post Posted: 09 Mar 2016 at 5:13pm
I am with you Charlie.
kylekai View Drop Down
Direct Link To This Post Posted: 09 Mar 2016 at 6:02pm
I did exactly that, but about 2 months later I had no power in the r-pod.  After an exhaustive search, it was determined that the switch failed.  Removed the switch, and back to normal.  Maybe it got wet and rusted, I don't know.   Something to keep in mind.
Direct Link To This Post Posted: 09 Mar 2016 at 8:13pm
We have had a couple owners have switch failures, usually a $3 switch that looks pretty much like mine. But Mine is an actual HELLA kill switch, going into it's 6th season, on it's second set of batteries and box, in a state that gets 60 inches of rain annually. No issues yet.
