gkooris
Calendar Event: Replacing the Interior Speakers Posted: 08 Dec 2014 at 6:19pm |
We just took delivery of our 2015 179. My only real complaint is the sound quality of the speakers. I don't know if it's the Jensen system or the speakers, but I've got to believe those speakers could do with an upgrade. Has anyone replaced theirs? Thanks, Geoff in CT
When in doubt, go strong and wrong
kymooses
Posted: 08 Dec 2014 at 7:17pm |
It's the speakers that are so bad. Your outside ones are even cheaper and worse. I've seen them swapped out a few times, mostly on the outside but there was someone a few weeks ago re doing the entire inside entertainment system with all kinds of new better things.
JStrube
Posted: 08 Dec 2014 at 7:39pm |
Funny thing, on my 181G, I think the outside speakers sound relatively good, the inside ones though, UGH! None are great though...
2012 181G
gkooris
Thanks Travis. I took a look at the Jensen specs, only a 48 watt amp! Might just swap out the whole thing.
SiberD
Posted: 08 Dec 2014 at 8:06pm |
Keep us up to date what you went with. There's not much room in the ceiling for bigger speakers.
I think we'll just take our Bose sound link portable speaker with us on camping trips.
gkooris
Posted: 08 Dec 2014 at 8:51pm |
I'm thinking of going to the more powerful Jensen system, the 975?, and getting some decent surface mount speakers from Crutchfield, most likely Polk. I'm going to replace the exterior ones as well. The newer Jensen has 108 watts as opposed to the 48 there now, and HMI as well. Might get a new screen.
Podster
Posted: 08 Dec 2014 at 9:14pm |
Originally posted by gkooris
Thanks Travis. I took a look at the Jensen specs, only a 48 watt amp! Might just swap out the whole thing. |
I assumed the low power amps in RVs were intentional to help conserve battery power when boon-docking.
Are they just cheap?
Cliff & Raelynn
Ranger 4.0/178
gkooris
Posted: 09 Dec 2014 at 7:37am |
I truly don't know, but I'd rather get some better sound. My speakers sound like soup cans attached to a transistor radio
Podster
Posted: 09 Dec 2014 at 8:36am |
Understood, nothing worse than the constant nag of poor audio. Interesting, my stock setup actually sounds OK. Good luck! Let us know how it works out and anything learned during the process.
Cliff & Raelynn
Ranger 4.0/178
Sleepless
Posted: 12 Dec 2014 at 8:58pm |
One speaker in our 178 sounded horrible. I removed the speaker grille and found a very loose connection of one of the wires to the speaker. After tweaking the connector with pliers, the sound was great.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
