  New Posts New Posts RSS Feed: Water pump
Topic ClosedWater pump
Hugozork View Drop Down
Direct Link To This Post Topic: Water pump
    Posted: 16 Jul 2011 at 6:31pm
Hi everyone,
It's hard to explain in english, how do i know that a water pump is working fine. I'm able to have water if i fully open the faucet and the water pump run all the time and i can heard the water pump working. If i open the faucet just a little the water pump run every 2 or 3 second and during 1 second.
So,
1- is it normal to clearly hear the water pump when it works?
2- is it normal the water pump run all the time when a faucet is full open?
3-is it normal it stop and start when i open the faucet just a little and i can see the water flow changing with the restart of the pump
Many thanks for your help
FrenchyPOD 171 2011
Toyota FJ Cruiser 2008 - MIA
Outbound View Drop Down
Direct Link To This Post Posted: 16 Jul 2011 at 6:55pm
Yes, its fine.  That is exactly how the water pump works. Big smile
Direct Link To This Post Posted: 16 Jul 2011 at 11:15pm
I agree, all 3 things are normal.
Direct Link To This Post Posted: 17 Jul 2011 at 6:19am
Also agree.  The pump will supply water "on demand".  As it sees a drop in pressure, it will turn on - off when it sees high pressure.  There are some modifications to help reduce the pump noise but, none that will completely eliminate it.
this_is_nascar View Drop Down
Direct Link To This Post Posted: 17 Jul 2011 at 9:58am
Yes, working like it should.  What you'll need to listen for, for example, is if no water has been turned on and you hear the pump come on.  That means you're loosing pressure due to a leak and would need to track that down.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 17 Jul 2011 at 10:36am
Thks for the response, something strange, when the faucet is open at 2/3 the pump cycle often like each second.
FrenchyPOD 171 2011
TIDALWAVE View Drop Down
Direct Link To This Post Posted: 17 Jul 2011 at 11:01am
The pump is pressure-sensitive and turns on when it senses lowered pressure.  Your public water supply has constant pressure and if you have a private well, there is usually an accumulator tank which helps store water and water pressure.  Because your Pod's pipes and faucet(s) are directly connected to its water tank, the pump has to run essentially every time you turn on a faucet and pressure drops.
An accumulator tank would help even out pump runs but there usually is no space available for a tank large enough to help.
TIDALWAVE
Direct Link To This Post Posted: 17 Jul 2011 at 6:43pm
Yes, it will cycle on and off quickly if you don't have the faucet open all the way.
You can buy an accumulator tank for a camper but I don't know how well they work.
bobthrash View Drop Down
Direct Link To This Post Posted: 25 Aug 2011 at 12:30am
I added an accumulator tank, about $50.00 thru Amazon.  Because water doesn't compress the pump comes on any time there is a pressure drop, the tank basically has captive air for the pump to push against and store a little water so the pump doesn't cycle every time you crack a faucet.
Bob & Maureen
172
2006 Tundra
