  New Posts New Posts RSS Feed: Entry door with wind proof hinges not closing
LeonMBarnes View Drop Down
Post Options Post Options   Quote LeonMBarnes Quote  Post ReplyReply Direct Link To This Post Topic: Entry door with wind proof hinges not closing
    Posted: 20 Feb 2025 at 6:33pm
Hi all,
Our 2016 RP178 has an entry door that won't close properly, has to be slammed. Was told by an RV mechanic that the wind-proof hinges don't allow any adjustment.
The door has progressively worsened, now it jams on the upper corner opposite the hinges and cannot be closed from inside the trailer, without there being a gap in that upper corner.
If closed from the outside an extra push on the top seats the door okay.
The door is not warped that I can tell.
Any help here will be welcome and appreciated.
Warmest Regards,
Leon and Johanne Barnes
Adventures in Retirement
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 6:44pm
How long have you had this RPod? There are a couple of factors that could be contributing to this. One is if you are using the stabilizer jacks to level the trailer. This causes the frame to flex and can be a cause of binding. Level with the wheels and ramps, blocks, etc. Then only use the jacks to stabilize. Another is that you may need to lubricate the hinges. If they bind, then they can distort the hinges which would affect alignment.
I don't know enough to say with any certainty what the cause of this problem is, but those are two things to check.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2025 at 9:38am
+1 ours did the same and turned out to be the friction hinges needing lubed. Clean them out with WD40 then lube with a real lube like TriFlo. Don’t worry, they will still have resistance to wind. If the frame is torqued, you will be able to re-form it by lightly tapping with a hammer and block of wood.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
