Does your air conditioner run constantly or cycle |
Grumpy-Chief ![]() Newbie ![]() ![]() Joined: 18 Apr 2023 Location: Florida Online Status: Offline Posts: 11 |
![]() ![]() ![]() ![]() Posted: 22 Apr 2023 at 7:23pm |
My 2022RPOD 153 AC does not cycle off when the temperature I’ve set is attained.
Is this normal?
seafans ![]() Senior Member ![]() Joined: 24 Nov 2017 Online Status: Offline Posts: 163 |
They do both. On cool/fan it should run continuously and cool/fan auto should run only during the cooling cycle. Check the instruction manual.
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
Mine cycles and even has 2 fan speeds it uses depending on demand. If you are sitting in full sun, it might not cycle because it never can get below the set point.
John
'16 R-Pod 180 |
