  New Posts New Posts RSS Feed: Pre clean for Dicor
Topic ClosedPre clean for Dicor - Event Date: 26 Jun 2018 - 02 Jul 2018
1Hpod View Drop Down
Direct Link To This Post Calendar Event: Pre clean for Dicor
    Posted: 26 Jun 2018 at 7:16pm
Ok Dicor is the Suggested Self leveling lap sealant.
Without spending extra money on the Dicor cleaner, I have seen YouTube where people have recommended denatured alcohol or mineral spirits. Does anyone have any experience or concerns with either of these two?
H&Rpod
'16 179
Tow '15 Ford F 150 FX4
Direct Link To This Post Posted: 26 Jun 2018 at 7:27pm
Just wipe down with the alcohol, and apply over the old. It sticks to itself just fine. If you get to much buildup, or want to remove some, just scrape with a putty knife, removing as much as you want/need. The stuff NEVER hardens.
Direct Link To This Post Posted: 26 Jun 2018 at 9:34pm
Thx
That is the most straightforward answer I could have desired!
H&Rpod
'16 179
lostagain View Drop Down
Direct Link To This Post Posted: 26 Jun 2018 at 9:53pm
It doesn't hurt to clean out the cracks with denatured alcohol as well.  An old tooth bush works well to break up any debris.  Pour some of the alcohol into the cracks after scrubbing to rinse out the debris.  You need to let it dry or blow out the liquid before applying the Dicor.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Direct Link To This Post Posted: 28 Jun 2018 at 9:53pm
Precleaned with the alcohol.
I’m getting a cover for winter especially under trees.
Dicor is almost fun to apply.
After being on the roof I see that I need to clean the roof and will do sides as well.
Any suggestions for a gentle cleaner that is easy to find on the shelf or at home already?
Thanks
H&Rpod
'16 179
mcarter View Drop Down
Direct Link To This Post Posted: 29 Jun 2018 at 3:14am
LA Awesome, sold at Dollar Tree and Dollar General, concentrated and can be mixed for the task - WORKS GREAT.
Direct Link To This Post Posted: 29 Jun 2018 at 7:17am
Absodamlutely.
Direct Link To This Post Posted: 29 Jun 2018 at 4:09pm
We used the denatured alcohol before application of Dicor and it worked great, no problems no issues.  Will have to travel to a Dollar Tree and see if we can find this LA Awesome, sounds like a good product to use on the finish.  Thanks Mark.
Direct Link To This Post Posted: 29 Jun 2018 at 4:23pm
I like the LA Awesome because you can mix from concentrate for the task, and it's cheap, and it works:) My Dollar General has it, I don't have a Dollar Tree.
