  New Posts New Posts RSS Feed: really basic question...
Topic Closedreally basic question...
PodBarb View Drop Down
Direct Link To This Post Topic: really basic question...
    Posted: 05 Oct 2017 at 10:34pm
Never removed or charged a battery so hesitant.  Do I just use a wrench to remove negative then positive connections?  Thanks.
2017 RPod 171
2017 Kia Sorento SX
sailor323 View Drop Down
Direct Link To This Post Posted: 06 Oct 2017 at 7:16am
That's all there is to it.  Don't be alarmed if the first terminal you disconnect sparks a little bit.  Also, you won't electrocute yourself.
Direct Link To This Post Posted: 06 Oct 2017 at 11:05am
Thanks! I'll be brave!
2017 RPod 171
2017 Kia Sorento SX
GlueGuy View Drop Down
Direct Link To This Post Posted: 06 Oct 2017 at 11:38am
Do be careful with the wrench. Do not get it in between the two terminals on top of the battery; it can produce very unpleasant results if that happens..Cry
codycountry View Drop Down
Direct Link To This Post Posted: 06 Oct 2017 at 1:07pm
If it is your Rpod battery you are talking about, all you have to do is plug the pod into electrical power and it automatically charges the battery or batteries.
Direct Link To This Post Posted: 06 Oct 2017 at 9:20pm
Well, that's the rub. It's in storage.
2017 RPod 171
2017 Kia Sorento SX
Direct Link To This Post Posted: 07 Oct 2017 at 5:08pm
We have taken both ours out since we purchased it in March 2011 for the winter months.  They go on the cement floor in our unheated garage.  Just yesterday I started the "winter charge" whereby I use a 2 amp trickle charge until it is fully charged.  Usually takes a day to day and a half for each battery.  They then sit there all winter long on the concrete till early April when I repeat the drill.  They are almost 7 years old now and get used a lot since we normally camp at national parks or other campgrounds where no electricity is available.
john in idaho View Drop Down
Direct Link To This Post Posted: 07 Oct 2017 at 7:56pm
When you are putting the battery back in, hook the Neg terminal last , so if you bump the frame with the wrench you won't spark there.
Direct Link To This Post Posted: 07 Oct 2017 at 8:33pm
Lots of good ideas. I'll have to see what I can manage. I'm hoping my son will set up the side of his house with a 30amp outlet, then I will keep my trailer there and can easily charge or put it in his garage and charge.
2017 RPod 171
2017 Kia Sorento SX
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 07 Oct 2017 at 9:34pm
You don't need 30A for storage and keeping the battery charged.  Mine stays hooked up to a 15 or 20a circuit, probably 20.  I can run the air and certainly keep the battery topped off.  I don't run the air much at all, but I have.  It wouldn't work to run the air, the microwave and/or the water heater on electric, but it works really well if you aren't trying to do that.
TT
FJ Cruiser
