2022 RP202 Fender Clearance
Forum Name: I need HELP!!!
URL: https://www.rpod-owners.com/forum_posts.asp?TID=16455
Printed Date: 07 Jun 2026 at 6:30pm
Topic: 2022 RP202 Fender Clearance
Posted By: superozzo
Subject: 2022 RP202 Fender Clearance
Date Posted: 07 Jun 2026 at 3:58pm
Brought home a 2022 Hood River Edition RP202 with the ST235 tires called for on side sticker.  Upon parking slightly unleveled, the front tires on both sides have minimal clearance in the wheel well.  Water tank is empty and trailer is sparsely loaded.  Ground is slightly unlevel to the door side and I leveled it out with Lynx blocks after these pics.  Sent dealer these photos and they told me all was normal that the tires will sit higher when parked.  Also had to do a tight turn to get into the tight spot.  Is that torsion tension that needs to be released by going back and forth a few times?
Any thoughts?  Even though bought "as is" California protects consumers from safety/road defects so I'm thinking about getting an RV tech out to look.  Dealer did the PDI, pulled up as they were pressure testing the water system for leaks.  They said PDI showed no issues.
Date Posted: 07 Jun 2026 at 4:00pm
