Dreaded Leak 179
Forum Name: I need HELP!!!
URL: https://www.rpod-owners.com/forum_posts.asp?TID=16437
Printed Date: 23 Oct 2026 at 7:19am
Topic: Dreaded Leak 179
Posted By: MikeP
Subject: Dreaded Leak 179
Date Posted: 07 May 2026 at 1:06pm
Hello friends. Looking for some troubleshooting guidance please. Of course the year I didn’t cover is when we got the rare snowfall that didn’t melt. Shame on me I know. Anyway, now I found myself with a leak which appears to be at or near the AC. The pic shows what appears to be the only part of the roof impacted. Visual inspection doesn’t reveal any gaps in the caulking where the roof and sides are joined. Any thoughts if water could be coming in from the AC or somewhere else I’m not looking? Any thoughts appreciated. And yes, I’m sick over my stupidity. Thanks
MP2112
Posted By: gpokluda
Date Posted: 07 May 2026 at 4:39pm
That looks like a Dometic AC. There is a foam gasket sandwiched between the upper AC unit and the roof of the Rpod. I believe there are four bolts that secure the two halves together. The first thing I would do is make sure those are tight which will compress the gasket and for a good seal.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Posted By: MikeP
Date Posted: 08 May 2026 at 11:07am
thanks for that. Do you by chance know specifically how those bolts can be accessed? I took off the inside cover and the top/shroud from the unit outside and they didn't stand up and say hi, so to speak.  thanks again
MP2112
Posted By: gpokluda
Date Posted: 08 May 2026 at 11:27am
I don’t remember them being hidden, but that was a long time ago. I believe Rpods had Dometic Penguin AC units. I would go to their site and download the installation instructions. That should show you where the bolts are.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
Posted By: MikeP
Date Posted: 08 May 2026 at 12:41pm
Thanks kindly
MP2112
