Park on grass fir winter
Forum Name: I need HELP!!!
URL: https://www.rpod-owners.com/forum_posts.asp?TID=16066
Printed Date: 25 Oct 2026 at 10:44am
Topic: Park on grass fir winter
Posted By: Danmas
Subject: Park on grass fir winter
Date Posted: 20 Oct 2024 at 10:10am
The winter is coming here in Canada. I will park my Rp177 on the grass in my backward. Should I put a tarp under to Block the humidité?
Posted By: StephenH
Date Posted: 23 Oct 2024 at 8:38am
Probably not necessary as long as any cover you put over the R-Pod does not seal all the way to the ground. As long as there is airflow under the R-Pod, the humidity there should not be excessive. My parents used to park a motor home over grass in New York State. The only thing they did was to have some small concrete pads under the wheels, but the grass was not covered. My sister and husband now park a 5th wheel on the grass. I don't think they put anything under the wheels, so that is not really needed either.
