Low water pressure/flow in shower
Forum Name: I need HELP!!!
URL: https://www.rpod-owners.com/forum_posts.asp?TID=15879
Printed Date: 25 Oct 2026 at 6:20pm
Topic: Low water pressure/flow in shower
Posted By: Rdenniso
Subject: Low water pressure/flow in shower
Date Posted: 22 Oct 2023 at 10:12pm
In our 2022 RP202, there is low water flow and pressure in the shower. I have a adjustable pressure regulator and set it at 45psi. When using the shower with city water connection, water flow pressure in shower is very poor. Using water pump helps, but flow/pressure is still very low. Is tis a common issue? 🤔
Posted By: StephenH
Date Posted: 23 Oct 2023 at 12:05am
Yes. Using the stock shower head is not ideal. I use an Oxygenics shower head. That is much better.
https://oxygenics.com/products/bodyspa-rv/ - https://oxygenics.com/products/bodyspa-rv/
Posted By: Rdenniso
Date Posted: 23 Oct 2023 at 12:47pm
Thanks for the reply! I'll give it a try.
