| Author |
Jason1507
Calendar Event: Trailer side plug wiring Posted: 20 Mar 2017 at 10:24am |
I recently bought a 2013 182g. Im about to do the wiring on my tow vehicle. Im wondering if there is a auxiliary wire hooked up trailer side of my rpod? If there is what does it run? The unit doesn't appear to have reverse lights. thanks
texman
Posted: 20 Mar 2017 at 10:39am |
not sure what you mean by trailer side ? does the trailer have zamp wiring? that is an extra set of leads to the battery.
Jason1507
Posted: 20 Mar 2017 at 10:50am |
From what I understand the center pin on the trailer side of the plug is either for reverse lights or a auxiliary battery connection. If there is no reverse lights on the rpod then I assume it would be a 12v auxiliary hookup. What does that 12v auxiliary power on the rpod?
voisj
Posted: 20 Mar 2017 at 10:57am |
If it's a 7 pin connector the auxiliary wire runs the reverse lights I have mine hooked up to a camera and a light on the back of my trailer. It terminates at the back of the whip under the trailer and it's just capped off.
SLOPODMODS
John&Sue,SLO,CA
Jason1507
Posted: 20 Mar 2017 at 11:00am |
what is the back of the whip?
Jason1507
Posted: 20 Mar 2017 at 12:27pm |
by whip you must mean the trailer 7 way plug?
voisj
Posted: 20 Mar 2017 at 3:44pm |
Originally posted by Jason1507
by whip you must mean the trailer 7 way plug? |
I call the wire that goes from the trailer to the tow vehicle the whip, I don't know why. The wire ends under the front corner of the pod the auxiliary has a cap on it. Some wires hook up to blinkers & stop lights, running lights, 12volt charging, ground, brakes and auxiliary. Out of my truck the auxiliary is prewired to the backup lights. And i hooked up a wireless video camera to it. I had a LED flood light on it also but it was to bright for the camera and I changed it to trailer power with a switch. rgds John
Trailer wire diagram,
SLOPODMODS
John&Sue,SLO,CA
Jason1507
Posted: 20 Mar 2017 at 5:15pm |
Gotcha! Thank you!
