| Author |
howmanyds
Topic: Wiring diagrams Posted: 19 Mar 2016 at 12:47pm |
Does Forest River provide wiring diagrams or service manuals?
I want to determine if I can put my battery shutoff switch inside the Rpod behind the TV.
I also need to find the best way to route wires for some 12v plugs I'm going to install.
CharlieM
Posted: 19 Mar 2016 at 2:11pm |
No such thing as wiring diagrams or brand specific manuals. FR's motto is "Let no two pods be built the same". What little factory documentation that may exist has never been seen by users.
You can place the battery cutoff pretty much anywhere it physically fits, but you'll have to find, identify, and trace the wiring. The cutoff must go between the battery and the power panel/converter, leaving the converter to power the pod when the battery is disconnected. Keep in mind that, if you significantly increase the length of the wire you should increase the size of the wire (i.e., go from #8 to #6 or #6 to #4) all the way back to the battery or converter to control voltage drop.
Adding 12V outlets is easy. Just run new #12 or#10 AWG wires from the new location to an unused fuse on the converter panel. Sometimes you may have to go under the floor and caulk the holes.
JandL
Posted: 20 Mar 2016 at 11:02am |
You can get a remote control battery switch and mount it close to the battery, that way you don’t have to runs new wires inside the trailer. Amazon carry’s them Marinco 701-MD RV Trailer Camper Motorized Remote Battery Disconnect $179 or Blue Sea Systems 7700 ML-Series Remote Battery Switch with Manual Control $145. I think both of these are expensive for something as simple as a battery switch. The auto reset breaker in the positive cable from the battery that came with my trailer is only 50 amps, so based on that you do not need a very large battery switch.
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
howmanyds
Posted: 20 Mar 2016 at 11:08am |
Great. Is the converter in the power panel? I don't want to accidentally go between the two since I don't know what a converter would look like.
CharlieM
Posted: 20 Mar 2016 at 8:37pm |
The converter is part of the power panel. Technically they are different, but they are both within the brown enclosure. Just intercept the leads between the battery and the back of the power box.
howmanyds
Posted: 20 Mar 2016 at 11:42pm |
How do I get to the wires behind the power panel? Do I need to remove it?
My 183G has the "pantry" cabinets on the other side and the walls are stapled in place. I could remove them and restaple of need be. There's probably a 4" space between the cabinet wall and the power panel wall.
CharlieM
Posted: 21 Mar 2016 at 7:48am |
I can't speak directly to the 183, but generally the panel has to be removed. It has several screws holding it in from the front. Be sure the battery is disconnected and the Pod is unplugged from shore (house) power first.
