  New Posts New Posts RSS Feed: High Point Microwave - Rotate on Convection
Topic ClosedHigh Point Microwave - Rotate on Convection
Don Halas View Drop Down
Direct Link To This Post Topic: High Point Microwave - Rotate on Convection
    Posted: 22 Oct 2015 at 12:12pm
The manual for the microwave is a bit lacking.
I've tried using the convection option of the microwave, and the rotation of the food continues.  This makes it difficult to use a square metal pan for heating up a barbecued pork shoulder or anything similar.   Seems uneccsary and not sure if it's by design or not.
Direct Link To This Post Posted: 22 Oct 2015 at 2:32pm
I think if you lift up the glass plate you can remove the plastic piece that rotates the plate. Then you can insert it back in place when you want the plate to rotate. Our microwave is a different make but I think that may be a common way they operate.
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 22 Oct 2015 at 3:17pm
...and that common sense, good and obvious observation is what makes blogs like this so beneficial.  Thank you.
