Fresh water tank vs on-road handling |
Post Reply
| Author | |
enaltrebor
Joined: 24 Jun 2026 Location: WI Online Status: Offline Posts: 2 |
Post Options
Quote Reply
Topic: Fresh water tank vs on-road handlingPosted: 10 Jul 2026 at 1:52pm |
Hi, we are taking our 2024 RP116 on its first boondocking outing soon. We routinely empty the tanks on the way out of RV parks. We want to fill the FW tank at home for this next trip.
I didn't see baffles when looking through the translucent FW tank wall. Fluids slosh when cornering. (40 gal of gas in a retrofitted tank, with no baffles, can destabilize a light pickup.) • Is sloshing of 250 gallons of water, low to the road, even a problem? • If a problem, will the hitch stabilizer help? (It's a size up from the minimum required.) • What other gotchas await us? Thanks, |
Do not go gently into that flood light.
Rage, rage, against the dying of the night. |
Rpod-Couple
Joined: 21 Jun 2021 Online Status: Offline Posts: 73 |
Post Options
Quote Reply
Posted: 10 Jul 2026 at 9:58pm |
Your fresh water tank should be 30 gallons, which weighs about 250 lbs. When the tank is full, it really can’t slosh much. And your trailer is probably 3000 lbs+. The water is less than 10% of the trailer weight. I tow with my fresh tank full with a mid-size SUV and haven’t had any issues with the water contributing to side-to-side sway. If anything, it adds weight on the tongue which makes for less side-to-side trailer sway.
Steve & Elaine
2021 R-pod 2023 VW Atlas Cross Sport |
enaltrebor
Post Options
Quote Reply
Posted: 11 Jul 2026 at 2:21am |
Thanks
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3441 |
Post Options
Quote Reply
Posted: 17 Jul 2026 at 1:56am |
In our case, a 177, the FW tank is behind the axle. For 15 years we always leave with a full FW tank as we usually boondock and love our sweet well water. As long as there is at least 10% of your loaded trailer weight on the a-frame (tongue) you are good to go. A friction bar is utilized for added safety.
Post Reply
