  New Posts New Posts RSS Feed: No 12v power
No 12v power
MiPa View Drop Down
Post Options Post Options   Quote MiPa Quote  Post ReplyReply Direct Link To This Post Topic: No 12v power
    Posted: 22 Mar 2026 at 5:01pm
Hoping the braintrust can make sense of this.
I can not run anything with 12vdc in my R179. However, everything works fine, if I am connected to shore power, or my tow vehicle. Bondocking is not an option until I figure this out. I plan on adding a second battery, but until I can sort this out. I do have a remote solar charging system as well.
Thanks for the input, Keith
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 12:27am
Hi Keith,
Unless you are hooked up to shore power, or hooked up to a generator, or have an inverter installed, your outlets are not going to function.  The 12v battery or batteries will run lights and furnace while boondocking, but nothing else.  We normally boondock with our older L.A. batteries.  The oldest will turn 15 years old next month, a 12v Interstate deep cycle while our newer one is a 5.5 year old Trojan T-1275.  We can go 5 - 6 days boondocking with this setup when night temps drop into the 40's, no solar or generator is utilized.  The fridge and furnace run on propane while the battery will run the lights and motherboard to the fridge and the spark ignitors to both fridge and furnace.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2026 at 7:20am
+1 what Jato said. The only electrical items that will work off your battery are lights, fridge (propane, 110v, 12v) and furnace (propane). To trouble shoot 12v issues, make sure your battery is fully charged, has solid connection to the cables, then check fuses.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
