Charging Lithium Battery |
Post Reply
| Author | |
JBTurner
Joined: 08 Jan 2026 Location: Grafton, Ohio Online Status: Offline Posts: 2 |
Post Options
Quote Reply
Topic: Charging Lithium BatteryPosted: 30 Jan 2026 at 12:12pm |
I don’t think the charger in my R-Pod 191 is lithium compatible. Will I be able to use a lithium battery and jut charge it fully with an external charger?
2019 R-POD 191
2013 RAM 1500 Sport 5.7 Hemi |
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2783 |
Post Options
Quote Reply
Posted: 31 Jan 2026 at 12:03pm |
All the the Rpods I've seen have typically had a WFCO converter. Early versions before 2019 or so typically would only handle SLA batteries (Sealed Lead Acid). In later years they started getting the ones that could also do LFP batteries.
I would check to see which model converter you have, then check the model number at the WFCO website. |
Post Options
Quote Reply
Posted: 01 Feb 2026 at 10:08pm |
You can upgrade the converter portion of the power center. I did so on our 2016 RP-179. I removed the converter and still have it here. It is a WF-8950L2-MBA. When we traded, the new trailer came with an automatic converter that can detect which type of battery it is charging and adjust accordingly. I am keeping the 8950L2-MBA as a backup in case something happens to the automatic one.
Post Reply
