  New Posts New Posts RSS Feed: Lithium batteries
Lithium batteries
JBTurner View Drop Down
Post Options Post Options   Quote JBTurner Quote  Post ReplyReply Direct Link To This Post Topic: Lithium batteries
    Posted: 28 Jan 2026 at 2:17pm
We have a 2019 Rpod 191. I want to use a lithium battery. Will I need to change the inverter to be able to charge it?
2019 R-POD 191
2013 RAM 1500 Sport 5.7 Hemi
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 4:48pm
You will need to make sure your your charger can charge a lithium battery since it has a different charging profile than a lead acid battery. There is usually a switch on it labeled Pb-Li. To charge a lithium battery, it should in the the Li position. If you do not have that capability on the charger, you will need to swap it out for one that does in order to get the full benefit of your Lithium batteries.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2026 at 11:59am
It's also good to get an LFP battery with (at least) freeze protection. LFP batteries will be damaged if they are being charged below freezing.
LFP batteries are generally OK to operate below zero (-5 to -15 depending on brand), so if you think you might be in an area where the temps will get that low, you might also consider ones with a built-in heater.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:03pm
or with a BMS that will not allow charging below 32F.
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: Today at 12:01pm
Freeze protection and built-in heater are two separate options. If you know you won't go anywhere where the OAT gets below 0°F, you can get ones that have the freeze protection.
Where we live in the mountains south of San Francisco, the coldest we've seen in the last almost 30 years has been about 30°F. We have a couple of devices outside where we have switched out SLA batteries and installed LFP batteries with freeze protection.
