Telegram.... @samjay231..Buy lsd tabs | Order LSD |
Post Reply
| Author | |
fvgf
Post Options
Quote Reply
Topic: Telegram.... @samjay231..Buy lsd tabs | Order LSDPosted: Today at 6:57pm |
LSD blotter tabs are the most popular way to dose LSD because of how easy they are to use. A newer method called LSD gel tabs follow a similar approach and has become more popular in recent years as well. Most user drop a single tab or part of a tab and hold it for 10 minutes or more. Others hold it for up to 45 minutes but evidence shows no difference in effects just 10 to 15 minutes later. After 10 minutes, take out the blotter and throw it away or swallow it. Again, research shows no difference in effects between removing the tab and swallowing it. You can also cut each tab into smaller pieces with a sharp knife. For microdosing LSD,cut the tabs into 9 even squares. The standard microdose is about 10% of a standard dose. You can choose to cut the tabs into 10 squares to be more accurate, but 9 is close enough and is much easier to divide evenly. : One dose of acid is equal to one full tab of acid. The potency of each tab varies with the concentration. LSD is extremely potent. This is why LSD is measured in micrograms rather than milligrams or grams. The threshold dose (the minimum amount needed for psychoactive effects) is only about 50 micrograms. A standard LSD dose is around 80–100 micrograms. This dose will supply a somewhat potent psychedelic experience without too much risk of being overwhelming. Microdose — Anything under 20 mcg Threshold dose — Depending on the users size and sensitivity to LSD. This can range from 20 to 60 mcg. Standard psychoactive dose — Between 80 and 100 mcg (one full tab of LSD). Heroic dose — Anything over 200 mcg is considered a heroic dose. The effects of LSD at this dose are comparable to DMT. Telegram.... @samjay231.. email...tomsyee00@gmail.com |
Post Reply
