  New Posts New Posts RSS Feed: Where should a jack be placed?
JSeiley View Drop Down
Post Options Post Options   Quote JSeiley Quote  Post ReplyReply Direct Link To This Post Topic: Where should a jack be placed?
    Posted: 24 Aug 2025 at 5:02pm
I'm new to the forum and to RV'ing.  I have a 2020 RPod 195, and while I just put new tires on it, I'm researching how to change a tire should that need arise.  Two questions:
1. It's been recommended to me that the BIG RED 10 Ton Torin Hydraulic Welded Bottle Jack would be a good jack for this purpose.  Does that sound reasonable, or do you have another recommendation?
2. I don't know where to place the jack in terms of lifting the RV.  My understanding is that using the axle is a no no (I guess it's hollow or something....just not structurally wise for the purpose).  What do you do for this?
Thank you, love the forum and my new adventure!
Joe
JoeS
2020 RPOD 195
2023 Toyota Tacoma OffRoad
Rpod-Couple View Drop Down
Post Options Post Options   Quote Rpod-Couple Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 9:21pm
I believe the concern is with jacking under an axle on a dual axle trailer since you are lifting half the trailer weight on an axle normally carrying 1/4th the trailer weight.
I place my jack under the axle of my 171 where the axle is bolted to the frame. All the force is transferred to the frame with no risk of bending the axle. I place a small piece old of carpet on my rolling jack pad when I lift to provide some cushion and avoid scratching the paint. Your 195 is single axle so this same lift point is fine.
Hope you enjoy your R-Pod!
Steve & Elaine
2021 R-pod
2023 VW Atlas Cross Sport
Post Options Post Options   Quote JSeiley Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 10:47pm
Thank you, that’s helpful!
JoeS
2020 RPOD 195
