  New Posts New Posts RSS Feed: mystery fan in fuse box? what is it for?
* Nomad * View Drop Down
Post Options Post Options   Quote * Nomad * Quote  Post ReplyReply Direct Link To This Post Topic: mystery fan in fuse box? what is it for?
    Posted: 18 Aug 2024 at 8:19pm
Hi,
There is fan in the center of the fuse area of my 2019 Forest River Rpod Hood River Edition that turns on and runs on it's own. Anyone know what this is for and how/if I can turn it off? I'm going off to boondock for several weeks and I don't want it to drain the batteries.
Thanks for your help!
Miranda
2017 RAM 1500
2019 RPod 180 Hood River
“Not all those who wander are lost.”
Rpod-Couple View Drop Down
Post Options Post Options   Quote Rpod-Couple Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 9:18pm
The fuse box contains the 120V AC to 12V DC inverter. The 12V charges the battery and runs the 12V lights, water pump, fan, radio, etc. The fan keeps the 12V inverter circuitry cool when it is putting out higher current.
Steve & Elaine
2021 R-pod
2023 VW Atlas Cross Sport
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 8:28am
+1. Make sure to keep the grill clean especially if you travel with a dog or cat.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Post Options Post Options   Quote * Nomad * Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 12:46pm
Ahh okay I understand, thanks so much!
 - So the fan should only be running when the converter is drawing from the batteries (to operate lights, water pump, fan radio, etc), Check.
 -so the fan should only be running when the devices are drawing from the batteries, Check.
 My situation is that I don't have any devices on, but the fan is still running... any ideas on what could be causing that?
I've gone around and checked to make sure everything is off, and the only thing that appears "on" is the antenna(?) on the roof that has a red light on. Could that be drawing so much 12V that it's causing the fan to go on?
I'm stumped!
2017 RAM 1500
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 12:50pm
It will also run when you are plugged into shore power and the battery is taking a charge.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
Post Options Post Options   Quote * Nomad * Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 2:08pm
Ah HAH! okay that makes sense! Thank you so much!
2017 RAM 1500
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 2:33pm
It will run even if you remove the battery and have the trailer plugged in. In that case, the converter is supplying the 12V power needed for the trailer's 12V circuits to operate. As others have said, the fan is to keep the converter from overheating.
Now to clarify something mentioned above. It is a Converter, not an Inverter. It takes 120V AC and uses that to provide 12V DC. An Inverter takes 12V DC and uses that to provide 120V AC.
Post Options Post Options   Quote * Nomad * Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2024 at 3:07pm
Thanks for the clarification StephenH.
2017 RAM 1500
