  New Posts New Posts RSS Feed: Low pressure gas hookup
Topic ClosedLow pressure gas hookup
Mbearden View Drop Down
Direct Link To This Post Topic: Low pressure gas hookup
    Posted: 23 Jan 2019 at 3:04pm
Our 2019 189 has a low pressure gas connection on the tongue.  Does only work with a “low pressure grill” or is there an adapter to use with another gas grill.
Mike Bearden
GlueGuy View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 3:48pm
Most grills operate on "low pressure". In most propane systems, devices usually operate on a pressure of about 11" of water. The tank on your R-pod should go through a regulator that's usually on the tank bracket and within an inch or two of the propane tank.
If your grill has another regulator, you just need to plumb it to eliminate the second regulator. That usually just means a different hose connection, because most grills have the regulator inline right at the propane tank.
Larry-D View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 4:17pm
Here's the one we use, you'd have to also get a hose.
https://www.ebay.com/itm/RV-Mounted-BBQ-Motorhome-Gas-Grill-BBQ-Trailer-Side-Mount-Barbeque-Grill-NEW/121166076296?epid=4017346135&hash=item1c360f9988:g:iR8AAOSwQYZW1LQJ:rk:1:pf:1&frcectupt=true
Motor7 View Drop Down
Direct Link To This Post Posted: 23 Jan 2019 at 6:27pm
Another option is to buy a 5Lb propane tank. They store in almost any compartment and will last for a couple dozen meals on a small grill. That is what I use....they ain't cheap though............
2016 R-Pod 176T
