Post Reply
| Author | |
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6483 |
Topic: Smoking/Stinky batteryPosted: 19 Jul 2018 at 8:32am |
My experience with boiling batteries was in an M577A2 (Command Tracked vehicle) on the Autobahn in Germany. The voltage regulator went bad and was boiling the batteries. In this situation, it was not the batteries at fault. We had to pull off and get out as the fumes were too much to take. We spent the night in sub-freezing weather in a rest area until the mechanics could get the part needed and effect the repair to get us back on the road to our intended exercise location. One spark and they could have exploded. Thankfully, that did not happen. I agree with letting the battery cool down. Keep clear of it until it does.
Joined: 07 Apr 2016 Location: Greenbrier, TN Online Status: Offline Posts: 3419 |
Posted: 19 Jul 2018 at 8:27am |
+1 - Best to never mess with a HOT battery,let it cool.
lostagain
Posted: 19 Jul 2018 at 7:52am |
Be very careful messing with a hot battery. They give off hydrogen sulfide gas and can be explosive. Many people have been blinded by battery explosions. As was pointed out by others, low water/electrolyte can lead to overheating. Best to turn off all charging power sources before investigating and make sure you have vented the battery very well before doing anything that could cause a spark.
Posted: 18 Jul 2018 at 4:00pm |
+1 to SH - a dry battery causes the convertor to charge. Easy to check, disconnect the battery, plug into power without touching battery leads and see what convertor is doing. Not to say it is impossible but converters have tendency to stop charging not go into "BULK". Glad I have a volt gauge.
Posted: 18 Jul 2018 at 12:01pm |
If the electrolyte level was already low and the converter was reading the charge as low, it could have put the converter into bulk charge mode. Was the bad battery the cause of the overcharging or the overcharging the cause of the bad battery? My suspicion is the battery.
Awchief
Joined: 04 May 2018 Location: Biloxi, MS Online Status: Offline Posts: 83 |
Posted: 18 Jul 2018 at 10:58am |
Check your converter output. Sounds like it is high and has cooked you battery.
Michael
Posted: 18 Jul 2018 at 9:56am |
+1 That is a boiling battery. Disconnect and let it cool, then check the electrolyte level. It is likely low. The battery is probably bad now and will need to be replaced. The fluid dripping is sulfuric acid so you need not just gloves, but acid resistant ones like heavy duty nitrile gloves. Face protection is also advisable as is a way to keep the acid from contacting your skin or clothing. You may have a cracked case which would be the source of the dripping liquid.
dr2428
Joined: 13 Aug 2016 Location: Nebraska Online Status: Offline Posts: 70 |
Posted: 17 Jul 2018 at 10:13pm |
I had a similar problem last year, at my year 2 of ownership. Just rotten egg smell, not smoking or dripping of liquid but battery did get hot. In my case I neglected to check the battery water often enough, it can dissipate and when low cause these type problems. Looking at top of battery you can see 2 caps that can be pryed off, use only distilled water and fill just until you can't see a space at the bottom of the tube. In my case, the battery was nearly completely dry, and ruined as it sounds like yours is. $100 lesson in my case. Google how to check the battery water. Please be sure to disconnect from shore power and let the battery cool before you handle it, eye protection and gloves are a good idea also. If the water isn't low you may have a charger issue. An auto parts store or your rv dealer will likely take the battery when you purchase a new one. If you are within a year of purchase it may be a warranty item. |
2017 RPod 179
2018 Chevy Colorado Z71 4x4 |
Sheila
Joined: 15 Apr 2017 Online Status: Offline Posts: 8 |
Posted: 17 Jul 2018 at 9:48pm |
2017 RPOD 178 plugged into house current. After 2 hours battery started to smoke and smell like rotten eggs and dripping liquid. Was plugged into same receptacle last year with no problem. Anyone???
Sheila
Post Reply
