Post Reply
| Author | |
Lear111
Joined: 20 Oct 2016 Location: Montgomery, tx Online Status: Offline Posts: 66 |
Topic: Converter problem?Posted: 15 Oct 2017 at 5:39pm |
2017 Rpod 180 about 11 months old. 3 weeks before warranty expires. I carefully monitor the batteries (2) with a permanent voltmeter and 90 percent of the time it reads 13.6 volt the absorption rate from what I read. Today after a long drive hooked up 30 amp power at a campground and everything good with air conditioner and appliances. However the volts are reading 12.5 volts on meter and Indepemdant voltmeter taken from distribution panel. I presume just battery power. Checked CBs recycled everything obviously getting 30 amps because Air is working. Seems to me a converter gone bad. I have read about problems with these. I have enough battery power for brakes to get home which is good. Any recommendations for an easy replacement. Does it sound like a bad converter. Any suggestions what to try.
Steve
Lexus GX460 R-pod 180 2017 1 black lab |
flat6s
Joined: 21 Mar 2016 Location: Burlington, Ind Online Status: Offline Posts: 84 |
Posted: 15 Oct 2017 at 7:34pm |
2017 R Pod 180 here. Went thru 2 WFCO converters. Kept the camp trip going each time by using a battery charger as a temporary converter. The converter is for 12 volt part of your electrical system only. Not the 110 volt, air conditioner, water heater, etc. You can replace with another WFCO converter or upgrade to a Progressive Dynamics cnverter, which is what I just finished doing. I am not extremely mechanical, and have earned the nickname "Joe mechanic" but I took my time and did this replacement by myself, with the help of Furpod on this forum. I strongly recommend the upgrade. EVEN IF you are still under warranty.
Also, your R Pod battery does not provide power to your trailer brakes. Your tow vehicle does. Best if luck
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6465 |
Posted: 15 Oct 2017 at 8:22pm |
One small correction: The battery is needed to supply power to the brakes if the hitch fails and the trailer becomes separated from the TV. When the pin is pulled by the safety cable, the battery powers the brakes to stop the trailer. That is one reason the cable should be slightly shorter than the length of the chains is so that it will pull the pin and activate the brakes, even if the umbilical should become disconnected. |
Lear111
Posted: 15 Oct 2017 at 8:57pm |
Excellent thank you. Figuring this all out slowly. I have a battery disconnect switch and need that on for the break away to work. I took a look at the wiring on the converter some look like easy access and some look challenging. Any recommendations and does amp power rating make a difference on an upgraded converter.
Steve
Posted: 15 Oct 2017 at 9:04pm |
The stock converter is 55A. I would not go with a lower rating.
Post Reply
