Post Reply
| Author | |
tsherv
Joined: 24 Mar 2017 Online Status: Offline Posts: 35 |
Topic: Running the microwave off of a generatorPosted: 04 Jun 2017 at 9:17am |
Hi,
I have a 2014 Rpod 179. I'm wondering if I can run the microwave / convection oven off of a 2,000 watt generator? I'm thinking of buying the Champion 2,000 Watt generator / invertor. I realize it probably won't run the AC, but what about the microwave (if there isn't a lot of other load)? Thanks!
Joined: 07 Apr 2016 Location: Greenbrier, TN Online Status: Offline Posts: 3419 |
Posted: 04 Jun 2017 at 9:30am |
Yes, I have a 2KW, it will run microwave. It will run AC if you disable 12 volt charging circuit, but it will not run both together.
henryv
Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
Posted: 04 Jun 2017 at 9:32am |
Why would running the microwave be more important than running the AC? I recommend buying the Honda generator and it's companion. Each $1000, but worth it I think since they run everything and you get top Honda quality, with fuel efficiency and quiet..nobody complains..
tsherv
Posted: 04 Jun 2017 at 1:00pm |
Thanks for the reply. We are going to be camping in cool temperatures...That's why the AC isn't important. I'm buying the generator for charging the battery and for the microwave.
tsherv
Posted: 04 Jun 2017 at 1:01pm |
I'm curious...How do you disable the 12 volt charging circuit? Is this easy to do?
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2735 |
Posted: 04 Jun 2017 at 1:21pm |
I've not found any specs on it, but I'm guessing that the microwave is around 1000 watts. Running the AC has got to be in the neighborhood of 1500 watts. The power required by the battery controller is going to be based (probably) on the charge rate, and (probably) won't be over 200 watts.
Those are all SWAGs.
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6465 |
Posted: 04 Jun 2017 at 2:27pm |
The first microwave we had that came with our R-Pod would not run onthe generator. When that had a problem and was replaced (under warranty), the second one would run just fine on the generator. The best thing that can be said is to try it and see.
The symptoms were: Microwave plugged in and generator running (it didn't matter if the microwave was plugged into its socket in the cabinet or directly via an extension cord): Microwave would start and within a second, reset. Convection side worked just fine. The start-up surge with the magnetron was too great for the generator to carry. The replacement convection/microwave did not have these issues. |
Posted: 04 Jun 2017 at 3:58pm |
tsherv,
YES - easy to disable charge circuit. I have had all spring to test combos with my 2K Generac, watts is not issue, amps are. Your normal 110 AC source, not on 30 A circuit is 20 amps. Your AC runs at about 14 with a surge to 16 when it comes on. Your AC charge circuit can pull 5-6 amps because it doesn't care if battery is fully charged or not. Your microwave will run on a 2K providing it does not have issues that SH said. Your AC will not normally, but might with a Honda at an added expense. Two ways to disable the charging circuit, if you have a battery disconnect shut the battery off, the converter will furnish 12V from AC line. If not shut the Converter CB off the 12 volts will come from battery, choices, right? It works. |
GlueGuy
Posted: 05 Jun 2017 at 10:55am |
The amps/watts on the charger should be directly proportional to the amps required by the batteries. When the batteries are very low, the bulk charge rate will be limited by the maximum output of the charger. As the batteries charge up, the load will go down. A 15 amp charge rate at 12 volts, will be roughly 1/10 of that on the 110 VAC side (or about 1-1/2 amps). I doubt seriously whether the charger ever goes above a 15 amp (on the DC side) charge rate.
Posted: 05 Jun 2017 at 11:35am |
Thanks GlueGuy,
I didn't get that detailed into the effort. What I know is my 2K genset will not run my AC with the DC charge circuit energized. It will operate AC with battery disconnected (via switch) or converter CB off. It will operate microwave with both battery connected and converter CB on, that is all I need to know. It will not operate AC and microwave, BTW. |
Post Reply
