| Author |
Dave & Donna
Calendar Event: Air Conditioner Posted: 03 Jun 2017 at 11:48am |
I had the air set on auto at 69 degrees. We went on a bike ride for 1/2 hr &
When we came back, water was leaking inside. Im thinkingI froze it up!? Just
Cking with you all for any advice!
Thanks. D.
D&D plus Rusty
2017.5 R-pod 179
Dave & Donna
Posted: 03 Jun 2017 at 2:38pm |
Hello All! It's been a couple hours and no go. The service department said to check for blocked drain holes on top of the pod, looked brand new, no water under cover at all. The top cover was cracked from over tightening at the factory. Service manager said probably bad unit & he can't get me in until middle of July! Only our 3rd. time out.
D&D plus Rusty
2017.5 R-pod 179
Posted: 03 Jun 2017 at 2:52pm |
Are your filters clean?
Dave & Donna
Posted: 03 Jun 2017 at 5:32pm |
Yes Sir! I even took them out because that is where all the water is coming from. I took the cover of the inside & out side & I'm running it...waiting to see where it starts. This is 3rd time out & 2nd time using the air!
I always say, baby steps! Wait & see!
D&D plus Rusty
2017.5 R-pod 179
Posted: 03 Jun 2017 at 5:46pm |
Have you physically removed cover and looked at drain? I know mine starts to flow after several minutes of running. Long shot, but it has to expel water. Not hard to remove cover. Cracked cover will not effect.
Posted: 03 Jun 2017 at 5:58pm |
Sorry reread your post and think you have removed cover. When you came back was it blowing cold or just leaking and not blowing cold?
Dave & Donna
Posted: 03 Jun 2017 at 7:52pm |
I again what to thank all who always try to help. This site is awesome! A friendly neighbor camping next to us came over. I always try to slowly think things over. He comes into the pod,looks up at the unit,cover off, and pointed to 1 of the bolts that holds the unit to the roof. 1/4 from being tight, it & 1 other also but not as much. Snugged all 3 & so far.....Nice & cool....& Dry!
D.
D&D plus Rusty
2017.5 R-pod 179
Posted: 04 Jun 2017 at 9:38am |
2nd post this week where loose mounting bolts were causing leak.
