  New Posts New Posts RSS Feed: black water tank sprayer connection
Topic Closedblack water tank sprayer connection - Event Date: 01 May 2017 - 01 Jul 2017
jimhibb View Drop Down
Direct Link To This Post Calendar Event: black water tank sprayer connection
    Posted: 01 May 2017 at 4:04pm
I feel real DUMB, I connected my water hose to the sprayer connection for my black water tank and then accidentally backed over the hose ripping off the connector from the trailer... my question is how can I fix it. can I glue it???? I have a 2015 RP-180.
Jim
we are semi-retired happy campers
2015 R-pod rp 178
2015 frontier club cab v6
Jim n Kathy
Charlie girl a wacky jack russel
mcarter View Drop Down
Direct Link To This Post Posted: 01 May 2017 at 5:10pm
Hard without seeing damage. If you pulled the connector from the Pod, which means you basically pulled the screws holding the connector, and didn't do any other damage. You can remove the screws, fill the back of connector with about 3/16" of silicon, reposition on side of Pod moving the screw pattern so that you are not using the old/damaged screw holes and remount the connector. The silicon will fill your old holes and the new screw locations will mount the connector. I had basically same damage to cable connector on my 178 when previous owner drove of with cable attached.
Direct Link To This Post Posted: 01 May 2017 at 6:15pm
+1
Direct Link To This Post Posted: 01 May 2017 at 9:38pm
Thanks Mike, actually I pulled the connector totally off the trailer. I am wondering if crazy glue would seal the pipe so it wouldn't leak and be usable? I will try to tomorrow and get to the storage place and take some pics
Jim
2015 R-pod rp 178
Jim n Kathy
